Eliminating the RABS Valve - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 04-10-2009, 03:17 AM Thread Starter
gnxtc2's Avatar
Has anyone eliminated the RABS Valve? If so, post some pics. Also what is your opinion of the elimination. Did it set any codes or illuminate any dash lights?
Thanks
Billy T.
gnxtc2@aol.com
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #2 of 17 (permalink) Old 04-11-2009, 01:47 AM
Re: Eliminating the RABS Valve
It will set a code and ABS light. I have built a bypass line before for testing. Not too bad to do it you can flare brake line or get correct size adapters to adapt a short premade line. Bypass it and keep it plugged in and the computer will never know.
tjbeggs is offline
post #3 of 17 (permalink) Old 09-08-2009, 03:28 AM
Metallitera's Avatar
Billy, did you go ahead & bypass it? Im thinking of doing the same?
-ReD
Fire Lieutenant/Paramedic, Tinkerer
1990 Jeep Wrangler YJ
Metallitera is offline
post #4 of 17 (permalink) Old 09-08-2009, 04:08 AM
What is the reason for doing this? I had a leak in the outgoing line right by the fitting, it set off the ABS light until I replaced the whole line and fixed the leak.
For Sale: 2000 F350, black cc sb 4x4
Jngreen is offline
post #5 of 17 (permalink) Old 09-08-2009, 04:12 AM
$$$$$ and RABS isnt true pulsating ABS. it dumps the pressure to the rear brakes in the event of the rear wheels locking up. ie. NO BRAKES when youre trying to STOP.
a reman valve, my cost, is over $100. if i can bypass it for a few bucks, or disable it for free (remove spring?) then i will. it will give me true, non ABS, stop when you mash the pedal, brakes. and that I like.
-ReD
post #6 of 17 (permalink) Old 09-08-2009, 04:22 AM
oil burner
tughill283's Avatar
i hate abs, i always remove the fuse and live with the light.
tughill283 is offline
post #7 of 17 (permalink) Old 09-08-2009, 04:26 AM
King of my own world
texaspowerstroker's Avatar
my light randomly comes on and off what does that mean?
97 F250 5 speed w/homemade flatbed, diy intake muffler delete, empty emissions device, 10k, 3" dp, 5" tip.
more to come.
texaspowerstroker is offline
post #8 of 17 (permalink) Old 09-08-2009, 04:27 AM
FNG
Dave's Avatar
Wish you could do that with a 6.0 but as soon as you pull the fuse you loose your speedo
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #9 of 17 (permalink) Old 09-08-2009, 04:29 AM
pull the codes when its on.
un do the connector under glove box. single wire. one end its red, other is black with orange tracer. ground black wire for a cpl seconds and ABS light will start flashing. count the flashes, including the last long one.
-ReD
post #10 of 17 (permalink) Old 09-08-2009, 04:32 AM
will try it tomorrow! thanks for heads up i didnt realize i could do that on a ford. on another note our right the abs sucks had a 96 ranger i trash cause my abs failed...airbags didnt work either.
more to come.
Human Verification
