1995 F250 Oil Leak - Page 4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #31 of 37 (permalink) Old 03-30-2009, 02:15 PM
97 OBS PSD
Aaron Ford's Avatar
Re: 1995 F250 Oil Leak
Thats the EBPV actuator blowing oil under the exhaust side of the turbo. If you look at the pics, it is certainly in line with it. Mine did this and had me baffled. It blows the oil out with enough pressure that it ends up in line with the actuator shaft, but the actuator itself is clean. Heat from the pedestal will thin the stuff enough that it runs off or is burned off. Mine finally had to fail completely to see it. It got so bad I was losing a quart a day. From what I understand from the PO, it had been doing this for years. I gutted the ebpv and actuator to solve the problem. Place a piece of paper (or something similar) over the hole where the shaft comes out of the actuator and you should see evidence.
HTH
Aaron
Aaron Ford is offline
post #32 of 37 (permalink) Old 03-30-2009, 10:09 PM Thread Starter
Originally Posted by robp823 View Post
How severe is it leaking???Enough to roll down the hole in the back of the block and look like a rear main seal leak??? It looks like at the high pressure oil line where it goes into the head you might have a leak.Also check your EBPV to see if its spewing out of that.You could also be sucking oil through the breather and it could be spewing out your MAF hose.My advice, 5-10 cans of brake clean, a really good drop light, and start the truck and sit and watch.
The leak isn't really bad, but if I leave it running in one spot for a little bit, I can see a couple drops on the ground. From what I can tell is, it is running down the drain hole and then it goes down the side of the oil pan and then drips off the bottom of the pan.
1995 Ford F250 4x4 Reg. Cab Auto
188,000 miles and all stock
Truck207 is offline
post #33 of 37 (permalink) Old 03-30-2009, 10:19 PM Thread Starter
HTH
Aaron
This may be a dumb question, but which part is the EBPV? Also, how would I go about fixing it/gutting EBPV? If you could let me know, that would be great.
Thanks for your help!
Truck207 is offline
post #34 of 37 (permalink) Old 04-01-2009, 03:05 AM Thread Starter
Bump....
Truck207 is offline
post #35 of 37 (permalink) Old 04-03-2009, 05:44 PM
Heath
rollingthunder's Avatar
EBPV (exhaust back pressure valve) It is under\behind the turbo on the passenger side. The vavle is bolted to your turbo and there is a rod on the bottom side that runs to an acctuator that is part of the pedestal. To gut it you need to pull the pedestal cut and weld some stuff up. Or you can get a ped without the EBPV. You really don't need it--Some dumb idea by Ford! You just need to be decent at welding to seal up the Oil passages.
Some one here or FTE had a write up with some pics that showed it clearly
2005 250 crewcab king ranch
arps, egr delete,coolant and oil bypass filters
4" turbo back MBRP
A-1000 fuel w\Reg return
Warrne 175\30's
rollingthunder is offline
post #36 of 37 (permalink) Old 04-04-2009, 04:39 AM Thread Starter
OK. Thank you for your info rollingthunder. Where would be the best and cheapest place to buy an actuator seal repair kit? Would this kit solve my leak, if it is leaking from the EBPV actuator?
Truck207 is offline
post #37 of 37 (permalink) Old 04-06-2009, 01:54 AM
Go to Powerstrokehelp.com... this guy talks about all these stuff. He says the real main seal... almost never ever a problem. Check out his vid's... very very smart wrench man.
Stumppullin is offline
Human Verification
