Turn engine over by hand - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-15-2013, 03:16 PM Thread Starter
I will be installing an injector for the first time this evening. Ill only be doing injector #3. I have sucked as much fluid out of the cylinder as I can. Im going to install the injector and keep the glow plug out, put on the valve cover and turn the motor over. I would like to do this by hand.
Will I be able to with only 1 glow plug out? I assume I will be using the crank pulley bolt to do this. Does anybody know the size of the bolt? Clockwise, correct?
ArXane is offline
post #2 of 3 (permalink) Old 10-15-2013, 08:02 PM
theoldgirl1990's Avatar
Re: Turn engine over by hand
Yes, suck as much of the fluid out as you can and just for insurance you could remove the glow plug and turn the engine over. The size of the bolt on the crank is a 24mm.
1996 F-350 cclb, H2E, e-fuel, srp1.1, custom tuning, banks intercooler, 3 in plenums, swamps babies, ARP's, comp 910's, Isspro EV2's, rsk v/c codes, 5 inch exhaust, king ranch seats, SD 10.5 axle, swamps idm, 6.0 fan, international w/p, hydroboost, SD trans lines, 6.0 trans cooler,6.0 P.S. pump
theoldgirl1990 is offline
post #3 of 3 (permalink) Old 10-15-2013, 10:02 PM
lindstromjd's Avatar
I turned my engine over with ALL injectors and glow plugs installed when I was doing my HPOP. Pissed me off to no end when I found the super heavy-duty loctite on the bolt for that thing. End point is yes, you can do it by hand.
1994.5 F350 Dually Crew Cab
7.3 PSD, 220k miles, ZF5 2wd, 3.55 LS
Current mods: T500, Rosewood 160/30's, Hydro-boost, 120v IDM, 6637 Intake
Mods in the works: TS-6 chip, Inter-cooler, 3" intake plenums, GTP38r, MarkFuga E-fuel
... also waiting on some free time and a few final parts for my Dana 60 straight axle swap.
lindstromjd is offline
Human Verification
