OBS chassis SD crew cab body swap=wiring nightmare. duh - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-23-2013, 11:12 PM Thread Starter
Hello....introduction complete
I usually lurk and glean information no matter what forum, but I feel that there may be a way for me to save time that would otherwise be consumed looking at several feet of schematics taped together with a pile of colored pencils....
With that being said don't try to talk me out of it its already mounted to the frame.
97 f250 ext cab 7.3 auto rolled.....350$ junkyard 2000 v10 crewcab SD body complete with pcm and body and engine harnesses.
Basically to search for this problem would be a combination of does this harness/cluster/pcm/blah blah blah work together, so I'm tackling it in one thread hopefully, let me know if I missed a post with good info.
I'm trying to come up with a combination that will leave me with as many SD components on the body as possible IE A/C and headlights are controlled by relays and gem rather than high current switches...the steering column is the same and ign switch hooks up the same and the pcm connector matches as does the engine harness connector but from what I understand the pinout for the eng connector is different. Probably due to the injector driver module, no coils etc. It's no biggie to use the engine harness, but when it comes time to connect the body harness there are three connectors instead of one...
Basically what I'm hoping to do is hook up every thing from the obs harness minus non essentials in the interior and then control the v10 pcm or maybe just relays to work the interior. Does anybody have any insight on this? I guess the obvious suggestion would be to get an early 7.3 harness complete and use that, but I'm on super low budget and trying to get this thing out of my yard!!! Oh sorry for the long post and thank you in advance
builtfromscratch is offline
post #2 of 11 (permalink) Old 09-23-2013, 11:16 PM Thread Starter
Question Re: OBS chassis SD crew cab body swap=wiring nightmare. duh
Oh yeah, I'm not putting a cummins in it.
post #3 of 11 (permalink) Old 09-24-2013, 12:16 AM Thread Starter
It would be nice to know exactly what functions the pcm sends to the GEM or bcm in the v10 truck, I know cruise/speed, ign switch pos, ambient air temp maybe, but what else? Somebody must have scanned one of these modules to know what pids it sees from the pcm. Guess ill get some printer paper and start tracing stuff tomorrow....
post #4 of 11 (permalink) Old 09-25-2013, 08:11 PM
zabeard's Avatar
seems like you would have been better off using a cab that aready had a diesel in it. I know several have used the newer PCMs in OBS trucks. So search for that stuff as it may help.
2003 Ford Ranger on 42s, COs, Caged, Fully built 5.4L DOHC, blah blah
1997 F350 CCLB 4WD Auto. Basics 4" Exhaust and 6637 filter.
zabeard is offline
post #5 of 11 (permalink) Old 09-25-2013, 08:42 PM
Patrick Feeley's Avatar
My only suggestion would be to get Electrical and Vacuum Troubleshooting Manuals (EVTMs) for both models and go circuit by circuit. As you mentioned, its time consuming (but there is really no way around it). Good Luck and Cheers!
Patrick Feeley is offline
post #6 of 11 (permalink) Old 09-25-2013, 10:37 PM
STILL LEARNING
Bradbilt's Avatar
My suggestion is to get a 99-03 7.3 harness and swap it out with the v10 one.
DONE
Bradbilt is offline
post #7 of 11 (permalink) Old 09-25-2013, 10:49 PM
co04cobra's Avatar
DONE
This is really your best option. I have and do a good many of these type of swaps. The pcm plugs in, but the obs harness is different. To make it work you would need repin the harness.
Since its a V-10 harness it is going to cause more issues. If you had both schematics and the time you could maybe set down and build harness's to interface the two, but it would take a LONG time.
The harness you really need is to an 99-01 7.3. The obs engine side harness, and most all sensors are also different and they really need to be changed. Is the truck going to be a manual or auto?
00 f250 some stuff done always more to do.
Best advice I have seen on here "If you cant afford to build it right you certainly cant afford to build it twice"
co04cobra is offline
post #8 of 11 (permalink) Old 09-26-2013, 02:46 AM
zabeard's Avatar
Anything is possible if you put the time into it.
I spent weeks wiring a Lincoln 5.4L into a ford ranger body harness.
You do need those schematic books though, worth every penny!!
zabeard is offline
post #9 of 11 (permalink) Old 09-26-2013, 06:43 PM Thread Starter
Thank you for your suggestions, the early 7.3 SD harness is looking better and better, but somethin kinda intrigues me about having two ecms communicating with each other ... I'll probably end up running the truck first with the obs cab harness tucked in the floor board and just plugged into the steering column...does the programable speedo unit have some kind of check it does with the pcm to run the truck? Thanks again
post #10 of 11 (permalink) Old 09-26-2013, 06:44 PM Thread Starter
Maybe I can convince the wife to let me use the spare bedroom as a wire harness building room.....hahaha
Human Verification
