1995 F350 7.3L Engine Swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 06-28-2013, 04:49 PM Thread Starter
7.3L Collector
I bought a 1995 F350 dump truck with the 7.3L Powerstroke back in May of 2012. The truck was pretty solid expect for the fact that the brakes were gone and the truck smoked at startup. Having a 1995 F250 with a solid running 7.3L, I figured I would be able to diagnose the problem and get it to stop smoking.
I replaced the injector O rings and check the resistance in the glow plugs to start. The old injector O rings were pretty decent, but they are under high pressure so it would be hard to tell by eye. By replacing them I felt I could eliminate them as a cause of the smoke. I replaced them, and it still smoked, but not as bad. During ‘field testing’ the truck died. I had to replace the injector pressure regulator (IPR) sensor. I replaced it and the truck started right up.
During a second round of ‘field testing’ the truck died again. This time it was a fuel issue. I replaced the fuel pump, in a parking lot, and the truck eventually started up after it was primed with fuel. The truck ran good, and passed inspection and diesel emissions. There was a noticeable difference between the F350 and my F250. My F250 feels like a rocket ship, where the F250 always dogged around and felt like it was going to die. I began to think it was related to injectors.
I decided to do some trouble shooting. I looked in and around the turbo for excess oil, and I did not see anything to make me think there was a major leak or anything. I did notice that the fins on the turbo were slightly bent, but the bearing was good and the turbo fan spun freely. I will mention now that the truck’s air box was completely smashed and held together with duct tape. (Not my doing…) I found a stock air box and the junk yard and swapped it into the truck.
After some thought, I decided to do a compression test. The compression overall was low. I also found some small debris in the top of the head. In my opinion, when the air box got smashed, it sucked small parts of plastic into the motor and caused some damage. I have not taken the heads off to take a look, but maybe after I pull the motor I will. After thinking about this for a little while, I decided to look for a replacement motor. I found a nice motor from a reputable guy that I have done business with and started to plan the swap.
After acquiring the motor, I decided to reseal as much stuff as possible while the motor is out and do as much preventative maintenance as I could. I also decided to install a new downpipe to replace the factory ‘pancake’ pipe. I’ll post some pictures of the swap as I move forward.
1995 F250 Turbo Diesel (My Nice Truck)
1995 F350 Turbo Diesel DRW Dump
Bremery is offline
post #2 of 9 (permalink) Old 06-29-2013, 01:04 PM Thread Starter
7.3L Collector
Re: 1995 F350 7.3L Engine Swap
Made some progress. Got the front clip off and the tranny unbolted from the motor. Just need to unbolt the motor mounts and disconnect some harnesses and it should be ready to come out.
Bremery is offline
post #3 of 9 (permalink) Old 06-29-2013, 03:17 PM
STILL LEARNING
Bradbilt's Avatar
Put a NEW pan on while the engine is out. And paint it with POR
Bradbilt is offline
post #4 of 9 (permalink) Old 06-29-2013, 03:25 PM
97250HD's Avatar
Wouldnt be a bad time to do oil cooler seals either
97 F250 eclb. 265k
- Fresh engine. d60. zf5. Some other stuff...
E99 f550 213k
- starts every morning...
97250HD is offline
post #5 of 9 (permalink) Old 06-29-2013, 04:06 PM
old Smokey's Avatar
I would replace the exhaust manifold bolts too. They tend to brake on the back of the manifold and cause a exhaust leak.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #6 of 9 (permalink) Old 06-29-2013, 09:11 PM
Terminator Nation
Also may be a good time to install a Tymar or 6637 type intake filter system.
old man dave is offline
post #7 of 9 (permalink) Old 06-30-2013, 01:47 AM Thread Starter
7.3L Collector
image.jpgI've got a new to me motor that I am going to go threw. The pan is solid, so I scraped it down and I am going to paint it with POR tomorrow. I have done this on my f250 and it has held up nicely. I am going to do the manifold bolts to the up pipes and one is already broken. I am going to look at the oil cooler seals tomorrow and figure out what I want to do. After getting the motor out this morning I spent most of the day degreasing the frame and preparing it for paint. I'm going to do some preventative maintenance while the motor is out. I can't figure out how to post multiple pics, so one will do for now.
Bremery is offline
post #8 of 9 (permalink) Old 07-01-2013, 12:12 PM Thread Starter
7.3L Collector
Everything is ready for paint, but all the prep took a lot longer than I thought. I got most of the parts I wanted to swap over to the new motor (fuel pump, fuel lines, vacuum pump, power steering pump, glow plugs, harnesses etc...) I hoping to do some painting tonight and hopefully put the new motor in this weekend.
Bremery is offline
post #9 of 9 (permalink) Old 07-08-2013, 05:57 PM Thread Starter
7.3L Collector
Got the motor in yesterday. I had a hard time getting the bolts that clamp the manifold to the up pipes off. I had to heat them up until they were cherry red and then I drove them out with a drift pin. (I thought I was going to have to do the manifolds, so I kind of have up and that wasted a lot of time). I got everything back together and put the motor back in the truck late yesterday afternoon. Hopefully get it back together a couple of nights after work this week, and get it up an running by the end of the week.
Bremery is offline
Human Verification
