97 f250 front axle shaft removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 12-12-2008, 04:03 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Workin on my friends 97 f250 D50 TTB. Replacing the ball joints and axle u joints. Havin a hard time getting the pass axle shaft out of the spider gear. Its been a while since i worked on one of these but dont they just "pop" out w a little effort? There isn't a "c" clip that i have to pull out, right?
And also his outer axle shaft i bad due to severly worn out wheel bearings. The axle has a groove worn into it where it has been rubbing the spindle. Anyone ever run into this?
Bradbilt is offline
post #2 of 9 (permalink) Old 12-13-2008, 12:57 AM
What else?
smokyred's Avatar
Re: 97 f250 front axle shaft removal
The passenger side inner shaft has a C-clip inside the diff, if you want to pull the shaft completely out, you'll have to drop the 3rd member. Otherwise, split the shaft where the slip boot is at.
I've never seen the axleshaft being worn like that myself, but I'm sure it's very possible. If it's not fixable or it's where the bearing rides, you're going to need another shaft.
Dave
smokyred is offline
post #3 of 9 (permalink) Old 12-13-2008, 02:13 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Well i pulled the 3dr member but the c clip got f'd up from tryin to force the axle out. Got a new inner spindle needle bearing, outer axle shaft,and c clip. Ended up not really needing the inner u joint but while we were in there it got it. 3 greaeable axle joints, 4 greasable ball joints, repacked wheel bearings, greased the spindle needle bearings, greased the steering linkage, tire rotation o and i cant forget the swimsuit calender from Collis truck parts for being a valued customer And the front end is like new
Bradbilt is offline
post #4 of 9 (permalink) Old 12-13-2008, 02:16 AM
Don't EFN worry about it
Aljay's Avatar
Thats a nice days work there. I did leaf spring bushings and center pivit bushings one afternoon as well as fix a botched adda leaf install from previous owne.I surveyed the front end of my 250 I too will have to do ball joints and seal soon as I can get it running and up here to DFW ! Nice info on the little things guys.
Tuned by T Wildman
Aljay is offline
post #5 of 9 (permalink) Old 12-13-2008, 02:22 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Luckley i had my two frinend doind most ot the grunt work. I was more or less there for my knowledge
Bradbilt is offline
post #6 of 9 (permalink) Old 12-13-2008, 02:24 AM
Aljay's Avatar
Originally Posted by diesel_brad View Post
Luckley i had my two frinend doind most ot the grunt work. I was more or less there for my knowledge and beer drinking
There fixed it for ya.......
Tuned by T Wildman
Aljay is offline
post #7 of 9 (permalink) Old 12-13-2008, 02:38 AM
What else?
smokyred's Avatar
lol, sometimes it pays to be the one with the experience, you get to "teach" someone else how to do it!
Dave
smokyred is offline
post #8 of 9 (permalink) Old 12-13-2008, 02:58 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
It funny. These two guys will spilt any farmall from a 686 to a 1486 and do a T/A in a couple of hours but they dont want to change their oil in their pick ups
Bradbilt is offline
post #9 of 9 (permalink) Old 12-14-2008, 04:34 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
haha i got a buddy like that, has a bad ass profarm ih, is a big truck mech. that can do a cluth job in a road tractor in 4hrs but usually cant remember the last time he changed the oil in his psd.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
Human Verification
