code p1668 help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-21-2008, 11:03 PM Thread Starter
Pearson's Diesel
smokin dually's Avatar
code p1668 help
I am working on a 96 that is throwing the p1668 code it says pcm-idm communication. I have tested the pcm and the idm on different trucks and they are fine. What other components can I check?
01 F350 cc dually 6sp conversion
00 F250 2.6 puller
early 99 F350 2wd daily driver
smokin dually is offline
post #2 of 6 (permalink) Old 09-23-2008, 06:08 PM
<-Friends bike
Re: code p1668 help
DTC P1668 and P1670 indicates that a communication error has occurred between the PCM and the IDM.
Possible causes:
Open fuse
IDM relay
Open or shorted IDM enable circuit
Open/short in EF circuit
Open/short in FDCS circuit
IDM powering circuits
PCM
Check for other codes
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
ActionRick is offline
post #3 of 6 (permalink) Old 09-24-2008, 01:18 AM Thread Starter
Pearson's Diesel
Re: code p1668 help
no other codes. I changed around the relays and the truck srarted, but now it has a short in it. The wait to start light flashes constantly and the lights in the dash flash. It's almost like you are turning the key on and off really fast.
00 F250 2.6 puller
post #4 of 6 (permalink) Old 09-24-2008, 01:43 AM
OEM Moderator
Tom S's Avatar
Re: code p1668 help
Just for drill disconnect the fuel heater. They like to fail and short on out the PCM circuit but I have not read of anyone having this exact set of problems. I would also be checking out those relays.
Tom
Tom S is offline
post #5 of 6 (permalink) Old 09-25-2008, 01:46 AM Thread Starter
Pearson's Diesel
Re: code p1668 help
I will try new relays tomorrow
00 F250 2.6 puller
post #6 of 6 (permalink) Old 09-27-2008, 03:26 AM Thread Starter
Pearson's Diesel
Re: code p1668 help
It was the relay.
00 F250 2.6 puller
Human Verification
