Neutral Safety Switch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-18-2012, 09:50 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Anyone know what wires need to be jumped for it to be bypassed?
I am trying to figure out why the truck will not turn over with the key
Bradbilt is offline
post #2 of 11 (permalink) Old 07-18-2012, 10:04 PM
<--BAGHDAD
95PwrSmoke's Avatar
Re: Neutral Safety Switch
if you havent tried this yet brad, try starting it in neutral or pull the shifter hard to the left and hold it and try starting it and let me know. my truck does this and it is do to a broken plastic bracket to the frame that my shift linkage runs through.
95 CCLB, 3"DP-4"SP w/5" Silverline Tip, TS 6pos. w/Scheid custom tunes, DIY Intake, Custom Built Tranny, FPR Mod, Glowshift 7 color Gauges, Ranch Hand all the way around
95PwrSmoke is offline
post #3 of 11 (permalink) Old 07-18-2012, 10:47 PM
Agjake11's Avatar
not sure if its the same but this worked on my 98 f150. you need to jumper the 2 wires closest to the firewall and the one furthest away of the 6 wires in the connector
04 F250 - 6.UHOH. Studded and Deleted By PSE, Fueled by Warren and Aeromotive, and Tuned by Gearhead.
08 Tacoma Work truck. V6 Power nothing, Radio, AC, and 4x4
Agjake11 is offline
post #4 of 11 (permalink) Old 07-18-2012, 10:56 PM
7.3 fan
why not pull the wires off of the trans, there are only 2 there!
99 f350 7.3 srw super cab 290xxx miles zf LUK clutch bully dog afe and 4" mrbp
00 f350 7.3 drw cc 165xxx miles 4" exhaust auto
00 ex 7.3 afe 4" MRBP 185xxx miles 4" exhaust
jestersv is offline
post #5 of 11 (permalink) Old 07-19-2012, 01:04 AM
Patrick Feeley's Avatar
As far as I can tell, on the 6-pin connector: Pins 1 and 2 are not used. You need to jump pin 3 (White/Purple Trace) to 4 (Teal/Light Blue Trace) and pin 5 (White/Pink Trace) to 6 (Red/Light Blue) to bypass the switch. Cheers!
Patrick Feeley is offline
post #6 of 11 (permalink) Old 07-19-2012, 01:17 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Neutral Safety Switch. NOT MLPS
But I figured it out, I did not put my clutch rod on right and I wasn't getting enough throw
Bradbilt is offline
post #7 of 11 (permalink) Old 07-19-2012, 02:48 AM
You had everyone cornfused, brad. On the ZF5, it's called the clutch switch, not the neutral safety switch; that only applies to the Eek4OD.
But for future reference, you jumper the two wires closest to the firewall to bypass it.
madpogue is offline
post #8 of 11 (permalink) Old 07-19-2012, 02:42 PM
My post was referring to the clutch switch. Cheers!
post #9 of 11 (permalink) Old 07-19-2012, 03:36 PM
97 7.3
aamartin89's Avatar
I just bought a 97 a few months ago and had a trashed clutch bushing. You essentially had to curb stomp the clutch to start it but it did fine shifting. Like they said, Under your dash theres a 6 pin connector. Clip the bottom 2 off the connector (closest to the firewall on bottom) and jump them together. Works great. You just gotta be smart enough not to try to start your truck while its in gear without the clutch in. (I still push the clutch in most times because its habit) Not a bad idea to push the clutch in for safety sake. Probably a redundant post but hope it helps......
aamartin89 is offline
post #10 of 11 (permalink) Old 07-04-2016, 05:27 PM
do you have a picture of that nutural switch please :)
crashtestannie is offline
Human Verification
