Hard start, rough running 94 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 04-25-2012, 03:50 AM Thread Starter
Mustangranch22's Avatar
Ok I just picked up a 94 7.3l. I have a few different issues/questions. When I got the truck the hpop leaked like crazy. Pulled it off and happened to pick up a 99 hpop. Did the swap with the drain back mod that I found on here. Truck still starts hard!!! All glow plugs are good. Harness under the valve covers are good. Once you get the truck started it idles horrible. (oh I changed the oil to 5w40 synthetic rotella) I put a temp gun on the manifolds. 3 cylinders are dead cold while it idles. Once it warms up its like a light switch gets flipped and the truck rins better than my 97 did I'm stuck on where to start with my diag. My scanner won't talk to the PCM, so I can't run a buzz test or watch cranking oil psi etc. Trying to decide if I have an oil system issue or some injectors bad. (sorry shoulda mentioned truck has 250k and I think they didn't do good pm on it). So do I send te PCM in and have it flashed to be obII compatible? Which if I do that who is good to send it to. Or try to find a 97 PCM? I know that'll help to diag obviously. Just curious too if there's any known oil issues in the oil system in the heads or anything. Thanks in advance since this has prob been asked 100 times.
Hot Rods:
1994.5 F-350 4x4 Powerstroke
1939 9N Tractor
1966 Chevrolet Chevelle SS
B&W Turnoverball Dealer
Mustangranch22 is offline
post #2 of 18 (permalink) Old 05-01-2012, 09:55 PM Thread Starter
Re: Hard start, rough running 94 7.3
Ok I picked up a pcm out of a 96 cheap so I'm going to plug it in and see if I can run the buzz test with it. I found another post on here somewhere that had the same numbers as mine and said that it should work to do so. I think #1,4,8 injectors are bad so heres hoping I can confirm with the buzz test.
Hot Rods:
1939 9N Tractor
post #3 of 18 (permalink) Old 05-01-2012, 10:01 PM
Why did you post in the SD section?
02 f250
countryboyrob is offline
post #4 of 18 (permalink) Old 05-01-2012, 10:05 PM Thread Starter
You got me damn it! I always seem to do that.
Sorry
Hot Rods:
1939 9N Tractor
post #5 of 18 (permalink) Old 05-01-2012, 10:11 PM
Sorry
Click thread tools and move thread.
02 f250
post #6 of 18 (permalink) Old 05-01-2012, 10:18 PM Thread Starter
There we go...sorry thought only moderators could do that.
Thanks
Hot Rods:
1939 9N Tractor
post #7 of 18 (permalink) Old 05-01-2012, 10:21 PM
Try the pcm yet?
02 f250
post #8 of 18 (permalink) Old 05-02-2012, 01:02 AM Thread Starter
Try the pcm yet?
Well no. Instead I read somewhere I could just put it into my scanner as a 96 and see if they'd communicate. So I tried that just now. Showed inj pressure hen the truck was cranking 175 rpm's to be 3000. Ran a buzz test it showed system pass. I plugged the glow plug relay in and the truck fires up but misses just as bad as ever. Watched inj psi at idle was 800 ish dyer to came back down from 3000. Truck doesn't appear to drinking oil so not sure if I should re prong the injectors that are cold? I checked them with a temp gun is how I figured which ones I assume are bad. I wanna fix it right not just throw parts at it while I learn.
Hot Rods:
1939 9N Tractor
post #9 of 18 (permalink) Old 05-10-2012, 10:13 PM Thread Starter
anybody know will there be any advantage to swapping the 96 PCM in my truck since the current PCM will communicate with my scanner if i enter it as a 96?
Hot Rods:
1939 9N Tractor
post #10 of 18 (permalink) Old 05-11-2012, 02:13 AM
Patrick Feeley's Avatar
If they are both for the same transmission, you could use it, but there would probably be no real advantage. You would need to clear any codes once its installed and then see what pops back up.
Patrick Feeley is offline
Human Verification
