1997 F350 7.3 Turbo hard starting and no power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 01-04-2012, 12:19 AM Thread Starter
flmeade's Avatar
1997 Ford 7.3 Turbo 4 x 4 duelly with automatic trans.
Hard starting unless it is plugged in 60 degrees or lower. Low power, max speed 70 MPH on e-way after 5 miles with petal to the metal and slows on hills.
Removed injectors and had them tested all were within limits and replaced all O rings.
Replaced all glow plugs.
Drained tank and put in fresh fuel.
Replaced fuel filter.
Pressure tested fuel system for leaks.
Replaced wiring harnesses.
Checked oil in HPOP
Replaced CPS also
This truck doesn't have a check engine light so I don't think any computer analysis will do me any good.
Does the hard starting and low power have a common link?
If I rev the engine up to 2500 RPM and then floor it it will baulk puff white smoke and then take off to max RPMs.
Thrown a lot of time and good parts at the problem with no resolution.
Any idea what my next step would be?
flmeade is offline
post #2 of 9 (permalink) Old 01-04-2012, 12:46 AM
hendricksbus's Avatar
Re: 1997 F350 7.3 Turbo hard starting and no power
welcome to psn. what glow plugs did you use? ZD-11 are the best! i personally was running atuolites before i made the switch,which helped ALOT! is your oil new or close to be changed? is your EBPV still hooked up? also filling out your sig with any mods that are done to the truck will also help the guys giving advice to help you. good luck.
1996 F-250,Ext.cab,LB,4x4
stock tires
180K,6 pos chip,Open air filter, 3'' down pipe,fpr mod,ccv mod
4.10s gears!
Boost, Pryo and transmission gauges
sonnax shift improver kit
bronco tank mod
hayden cooler for transmission
hendricksbus is offline
post #3 of 9 (permalink) Old 01-04-2012, 01:27 AM
I'd check all your pressures when running; hpop, fuel pressure. MOnitor pressures cold, as well as after the truck warms up.
Whats the condition of your IPR?
Did you run the injectors tests warm as well as cold?
Chop Cut Grind Weld
96 RC 7.3 auto, rebuilt tranny, 3" dp, 4" to the back, PHP hydra, WW2/1.0 housing, stock injectors and hpop, efuel w/bb tightwad reg return, b-codes w/4" lift blocks, 3.5" rsk and x codes, 34.5" tire
ericlouie1 is offline
post #4 of 9 (permalink) Old 01-04-2012, 06:13 AM
Boost96's Avatar
Id test the glow plug relay to see if its working properly with the cold start issue. The low power issue could be a number of things, seems like you're on the right track though.
Boost96 is offline
post #5 of 9 (permalink) Old 01-04-2012, 06:15 AM
Boost96's Avatar
You can still have codes even if the cel isnt on.
Boost96 is offline
post #6 of 9 (permalink) Old 01-04-2012, 06:57 AM
OBS F350's Avatar
Exhaust smell sweet at all (antifreeze)? Might have a blown HG, don't know if that will cause hard starts, but anything is possible.
96 F350 zf-5, Rosewoods, 6637, mbrp, southbend, autometer, Rough Country. SOLD
08 f250 auto, dpf/egr delete, afe intake, Gearhead tunes
:, cold side pipe and cfm+ intake elbow.
OBS F350 is offline
post #7 of 9 (permalink) Old 01-04-2012, 07:15 AM
needs more fuel
96f350psd's Avatar
I would do a compression test. The white smoke sounds like injector orings.
-Mason
96 f250 xl reg cab lwb 7.3 zf-5 3.5" straight pipe with
87 f150 xlt 302 original aod 3:55s straight pipes
90 bronco 6" lift 35s 302 aod, locked rear end
89 f150 302 aod 4x4 15x8 mb razors 33" swampers
And like paul said, a smoke tune on 90cc injectors is about as useful as dial up internet when trying to watch porn.
96f350psd is offline
post #8 of 9 (permalink) Old 01-04-2012, 10:33 AM
excavator's Avatar
Who tested injectors? They would have to measure armature plate spec to see if poppet valves are good or bad. If bad, it will not start when oil is cold and thick.
96 F250 XLT 4x4 210000 miles Dana 60, Baby Swamped,Tony Wildman tunes,AutoMeter Pyro Boost Trans ,DPP downpipe,Tymar intake BTS TRANS
e99 f350 cc/lb drw php hydra plus Tony Wildman tune
excavator is offline
post #9 of 9 (permalink) Old 07-03-2012, 12:32 PM Thread Starter
flmeade's Avatar
Ended up being the ICM. Swapped it out with another from a friends truck and it started and 100% better. Got rebuilt unit for $165.00.
flmeade is offline
Human Verification
