7.3 Powerstroke Injector removal and install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 08-31-2011, 02:15 AM Thread Starter
Famous words "Watch This"
ascrap2003's Avatar
Finally got some injectors, well 4 anyway. Ryan Casserly Stockers
To start I removed the vc & gasket then removed the oil plug as seen below. Make sure the alen wrench is a snug fit. There are 2 of them one on left top of head & one on right, this beats purging the cylinders when done.
Next you gotta remove the oil spout bolt & two injector hold down bolts.
You gotta use a wrench for the bolt under the injector plug.
Focker in law took off with some of my tools so I used the open end of a 1 1/8 wrench to pry injectors worked pretty nice.
Next just remove injectors slowly "So that brass washer dont fall off" one at a time, now just install new injectors seating them with a rubber mallet & reverse the whole process.
Torque everything to spec.
2002 F350 SuperCab SRW Lariat, Hutch Mod, EBPV Delete, Straight Pipe, Chipped
2007 F550 Crew Flatbed
My websites:
ascrap2003 is offline
post #2 of 8 (permalink) Old 08-31-2011, 03:06 AM
biggreen96's Avatar
Re: 7.3 Powerstroke Injector removal and install
Just fyi you only need to remove th bolt on the out side to remove injector.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #3 of 8 (permalink) Old 08-31-2011, 04:39 AM Thread Starter
ascrap2003's Avatar
Outside? Ah ok I get you now!
My websites:
post #4 of 8 (permalink) Old 09-21-2011, 03:22 AM
Black_Clouds's Avatar
i removed my injectors and modded them and now i cant get my truck to start..i filled the hpop with oil and there is fuel in the bowl...any tricks to getting the air out quickly instead of just cranking?
96 F-250..5 speed,3.55,285/75/16 toyomt,ts 6 pos, DI tunes, 4 inch MBRP straight pipe,TYMAR intake,AFE Big Boost filter,173,xxx, Stroked A codes (stock nozzles for now) E fuel, LUK Clutch, solid flywheel
Black_Clouds is offline
post #5 of 8 (permalink) Old 09-21-2011, 03:40 AM
keep on crankin, it takes awhile. just let your starter cool between tries so you don't burn it up
-John-
1996 F-250 Ext Cab Long Bed 4x4 w/ a few mods
jmsmith76 is offline
post #6 of 8 (permalink) Old 09-21-2011, 05:27 AM
powerstroker66's Avatar
i left the injectors unplugged and the glow plugs out then cranked it to build pressure and make it easyer on the starter. Then re-installed the glow plugs and pluged in the injectors and she fired over with in 2 15 second cranking cycles.
powerstroker66 is offline
post #7 of 8 (permalink) Old 09-21-2011, 04:08 PM
STILL LEARNING
Bradbilt's Avatar
Good plan
Bradbilt is offline
post #8 of 8 (permalink) Old 09-21-2011, 04:32 PM
All that does is purge the cylinders. I do however reccomend for everyone to do this. Taking out the oil galley plugs sometimes isn't enough IMO.
late 99 black CCSB
OUTLAW101 is offline
Human Verification
