Code P0475 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 08-11-2011, 01:37 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Code P0475
Exhaust Pressure Control Valve Malfunction
What would cause that code to show up every time I start the truck
Bradbilt is offline
post #2 of 11 (permalink) Old 08-11-2011, 02:06 AM
strokefreak
strokefreak's Avatar
Re: Code P0475
maybe the ebpv? mine cycles everytime i start,and then opens up.
1996 Powerstroke. 159000 miles.
Custom F-250 Duallie Conversion.
Tymar - gauges - Swamps Tunes - MBRP Turbo back exh. Swamps HiFreq/HiVol IDM. Full Force Stage 1's. WW2. T500. SOLD.
2003 CCLB F-350
Current toy / exploder.
strokefreak is offline
post #3 of 11 (permalink) Old 08-11-2011, 02:33 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Re: Code P0475
I dont even hear mine, I just figured since it was warm out
Bradbilt is offline
post #4 of 11 (permalink) Old 08-11-2011, 02:42 AM
strokefreak
Re: Code P0475
mine will cycle even when its warm. is yours unplugged or gutted?
2003 CCLB F-350
post #5 of 11 (permalink) Old 08-11-2011, 03:02 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Re: Code P0475
Tell you the truth, I have no clue
Bradbilt is offline
post #6 of 11 (permalink) Old 08-11-2011, 03:13 AM
Re: Code P0475
Unplug it to be sure, don't want to have it get stuck closed. Probably the mechanism in the pedestal is shot. Does it kick on fine in the winter?
late 99 black CCSB
OUTLAW101 is offline
post #7 of 11 (permalink) Old 08-11-2011, 03:13 AM
Demon Dually
speeddemon31176's Avatar
Re: Code P0475
If it is unplugged, gutted, malfunctioning, or gone all together you will get that code. Mine is gone as I have the h2e and I get that code all the time.
speeddemon31176 is offline
post #8 of 11 (permalink) Old 08-11-2011, 03:32 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Re: Code P0475
I only have had the truck for about 4 months.
As for having it unpluged, I have had it unplugged on 2 of my other trucks but never had a code
Bradbilt is offline
post #9 of 11 (permalink) Old 08-11-2011, 08:48 PM
Patrick Feeley's Avatar
Re: Code P0475
Brad, is this on the 97? I'm not sure if this is a 97 thing only or not (probably not)
Here's some info from the "1997 MY OBD System Operation Summary for 7.3L Diesel Engine":
Exhaust Pressure Regulator (EPR) Valve Check Operation:
DTCs: P0475 – Exhaust press control valve malfunction
Monitor execution: Continuous
Monitor Sequence: None
Sensors OK: Not applicable
Typical Monitoring Duration: Internal to Chip
Exhaust Pressure Regulator (EPR) Valve Check Entry Conditions: No entry conditions
Exhaust Pressure Regulator (EPR) Valve Check Malfunction thresholds: Actuator driver status indicates open/short
Here is probably a better summary: "Exhaust Back Pressure (EPR) Regulator"
Hope that helps. Cheers!
Patrick Feeley is offline
post #10 of 11 (permalink) Old 08-11-2011, 11:44 PM
biggreen96's Avatar
Re: Code P0475
Brad if it is a Cali model truck it will throw that code when unplugged but not on the federal trucks.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
Human Verification
