97 f350 death wobble/hop - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 07-30-2011, 03:12 PM Thread Starter
They guys! i am now a proud powerstroke owner! I just bought a 97 regular cab f350 with a shackle flip about 6" of lift on 37's. i had a problem the other day when i hit a couple bumps in the road at probably about 35 and it went nuts, the front started hopping really bad like you were driving on a washboard until i slowed down then it went away. Now One- i looked under it and there is no trac bar, two the 37s are fluid balanced. I would imagine i should start with a trac bar but idk how big of a drop bracket to get for the mount and where to get that and a trac bar. i jacked it up and the ball joints are tight but the leaf spring bushings look like they have had better days and thats pretty much all that keeps my axle from moving side to side right now. any help opinions or experience is appreciated! thanks
corybens11 is offline
post #2 of 27 (permalink) Old 07-30-2011, 04:42 PM
STILL LEARNING
Bradbilt's Avatar
Re: 97 f350 death wobble/hop
Your track bar should be parallel with the drag link. That should get you close to a measurement
Bradbilt is offline
post #3 of 27 (permalink) Old 07-30-2011, 07:38 PM
gnxtc2's Avatar
You need to get a trac bar under there. Don't ask I how I know
Replace all the worn out components.
And welcome.
Billy T.
gnxtc2@aol.com
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #4 of 27 (permalink) Old 07-31-2011, 03:49 AM
weareweird69's Avatar
Also make sure the steering box is in adjustment after you put the track bar on...
weareweird69 is offline
post #5 of 27 (permalink) Old 07-31-2011, 05:19 PM Thread Starter
what do you mean about the steering box?
post #6 of 27 (permalink) Old 07-31-2011, 06:12 PM
Theres an adjustment on the box. You can adjust it to tighten the box, but you CAN overtighten it and cause the box to wear out inside.
Theres a jam nut, and a screw on the top of the box opposite the pitman arm. loosen the jam nut, and tighten the screw a 1/4 turn at a time, then tighten the jam nut and try it out.
post #7 of 27 (permalink) Old 07-31-2011, 06:44 PM Thread Starter
ok ill have to do that too, i dont know if that would cause it tho? it doesnt seem like its in the steering, more in the suspension, also did these come with sway bars, mine doesnt even have any mounts
post #8 of 27 (permalink) Old 07-31-2011, 07:21 PM
Like I said get the track bar on first. Is there play in your steering wheel? My lightnings death wobble was from the loose steering box. Too much free play in the steering let it wobble badly at random
post #9 of 27 (permalink) Old 08-01-2011, 06:14 AM
Terminator Nation
Too much of an adjustment and the steering will not want to return to center. You'll know it when you do it.
old man dave is offline
post #10 of 27 (permalink) Old 08-01-2011, 10:43 PM Thread Starter
ok well im gettin a track bar and then ill just take a measurment and get a braket and get new bolts from ford then ill adjust the box and see what it does, mayb rotate the tires? if that doesnt do it mayb ill have to take the fluid out and get them balanced normaly? did 97 have a sway bar by the way?
Human Verification
