1997 F250 problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-10-2011, 08:23 PM Thread Starter
DieselAddict
j.soffa's Avatar
1997 F250 problem
While driving to work a few hours ago my truck just died in the middle of driving. Started right back up while coasting and check engine light came on. 5 seconds later disappeared. Just swang by autozone to get a code, but they said nothing was logged. I've noticed that within the past couple weeks my idle has been degrading. very choppy. Also my voltage meter on my dash started acting funny. It started not moving as far after the glow plugs finish (usually was around the m and a, and will just randomly pick a spot every time I run the truck. Still seems to be charging the batteries... i think. Had it tested at autozone, they said it was fine. Only recent change was a cruise control recall and oil change 5 days ago.
Any input would be helpful. Just at work now. Thanks!
Truck has a 5 month old 250 amp alternator
2month old batteries
New Starter
New Stancor GP relay, all GP's check fine.
Black CPS 2 months ago
trucks got 240,000 on the clock.
1995 F350 7.3L T444E (not powerstroke) Stage 2 Inj, Terminator HPOP, TS 6-pos.
j.soffa is offline
post #2 of 4 (permalink) Old 06-10-2011, 10:45 PM
Re: 1997 F250 problem
Autozone scanners wont work on our trucks.
02 f250
countryboyrob is offline
post #3 of 4 (permalink) Old 06-10-2011, 11:47 PM
Famous words "Watch This"
ascrap2003's Avatar
Get a scan first
Also check icp sensor for oil, valve cover gasket connectors for oil/burnt/broken pins.
Could be simple or a combination of problems being your truck is old
I know from experience. Other possibles
include ipr sensor & or connector, faulty cps connector or wires, faulty/chaffed harness wiring.
But hopefully something simple that will show up with a scan
get with a good diesel shop or ford for a scan & have them run
a complete scan along with cct & buzz tests then go from there.
that is where I would start.
2002 F350 SuperCab SRW Lariat, Hutch Mod, EBPV Delete, Straight Pipe, Chipped
2007 F550 Crew Flatbed
My websites:
ascrap2003 is offline
post #4 of 4 (permalink) Old 06-11-2011, 04:56 AM
Patrick Feeley's Avatar
Also, take a quick look and see if the "tin nut" on the IPR is loose or missing. Cheers!
Patrick Feeley is offline
Human Verification
