Transfer Case - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-17-2011, 08:33 AM Thread Starter
Krause's Avatar
Transfer Case
Ok guys, sorry but I need to get some solid answers before I can move on in my little bit of research. I tried searching, cant seem to lock down the info I need. What transfer case specifically is in the OBS trucks, 1996 in particular, both automatic and manual. And if someone is extremely knowledgeable, what transfer case in the the 7.3 super duties, both automatic and manual zf6's. Thanks in advance guys
Regards
Krause
96 XLT ECLB. 6.0 intercooler. 4" aero turbine, gearhead tunes. Coolant filter & CCV mod. SD Dana 60 3.73 3.5 RSK V-codes, 35 inch toyos, 18inch M/T classic locks. 260000Km
Krause is offline
post #2 of 6 (permalink) Old 05-17-2011, 02:48 PM
Re: Transfer Case
I believe its a Borg Warner 1356. I could be wrong but,that is what I've been told.
Rodknocker is offline
post #3 of 6 (permalink) Old 05-17-2011, 04:05 PM
(520)465-7971
NotStock's Avatar
Re: Transfer Case
The 99 and newer has either an NP 271 or 273 depending on whether its manual or electric engagement. The bolt pattern and other dims are the same between those two transfer cases. I'm unsure of the obs trucks.
NotStock is offline
post #4 of 6 (permalink) Old 05-17-2011, 07:44 PM
Re: Transfer Case
1995's were 1356 '96-97 were BW4407's
email:
Website:
OBSWIZ is offline
post #5 of 6 (permalink) Old 05-18-2011, 06:52 AM Thread Starter
Krause's Avatar
Re: Transfer Case
thanks guys, appreciate it
Krause is offline
post #6 of 6 (permalink) Old 05-18-2011, 09:10 AM Thread Starter
Krause's Avatar
Re: Transfer Case
OK sorry guys, so heres the question now. The NP 271/273 was used with the 4R100, which is almost the same trans as the e4od. So does the BW 4407 bolt up to the 4R100, and the vice versa with the NP 271 bolting up to the E4OD? And was there separate versions of the NP 271 used for zf6 and 4r100, or are they virtually the same t-case for both manual and auto?
If you see what im getting at here, really im wondering if I found a zf6 with no t-case (or a electronic shift t-case), could I merry my manual shift BW 4407 to the zf6?
Thanks guys!
Krause
Krause is offline
Human Verification
