97 powerstroke low boost and power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 40 (permalink) Old 04-21-2011, 06:46 AM Thread Starter
00stroke97
97-BIG RED's Avatar
i have a 97 f250 powerstroke that i have had a major loss of power and boost and poor fuel mileage. it started when my buddy tried putting his edge cts on my truck brfore setting his back to stock. it froze his edge up and had t0 have it reset. my truck had always had a bit of sputter to it pulling in third gear but would still get up and go. i have had my pcm reflashed but didnt help. i do have oil in the icp sensor. the truck starts up fine and runs fine but if i get on it boost doesnt build till about 2 and half grand 3rd gear (5 speed) its real sluggish. ive checked the uvc harness by unpluggin each conector one by one and each time the truck ran different. i unpluged the icp and the truck ran no different. it does run better with the map unplugged but i have switched it out and didnt help. now im lost can it be the icp or another sensor maybe ipr any help thanks guys
97-BIG RED is offline
post #2 of 40 (permalink) Old 04-21-2011, 02:24 PM
Cratos's Avatar
Re: 97 powerstroke low boost and power
could be boot or plenum leak mix up some sopy warte ans spray it around the boots and plenum you may have a loose or leaking boot or the plenums may have to be resealed with the gray goo. how is you fuel pressure and have you changed you filter latley? fule and air = boost so one or the other is laking.
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #3 of 40 (permalink) Old 04-21-2011, 04:00 PM
95powersmoker's Avatar
Check your uppipes for soot on them or the firewall...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #4 of 40 (permalink) Old 04-21-2011, 04:29 PM
OBS Addict
7.3psd97444's Avatar
^ what they said.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #5 of 40 (permalink) Old 04-21-2011, 05:34 PM
i have a similar issue except the turbo one day got real loud so i try to keep the revs down so i dont go into surge untill i can look into the leak or whatever is causing the turbo to rev too much
ltjag101 is offline
post #6 of 40 (permalink) Old 04-21-2011, 06:08 PM
OBS Addict
uh a leak wont cause over speeding the turbo. you will loose boost(turbo speed).....
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
post #7 of 40 (permalink) Old 04-22-2011, 01:50 AM Thread Starter
00stroke97
97-BIG RED's Avatar
have a new fuel filter only about three months old ill go try checking the the boots with soapy water. i havent checked the fuel pressure yet
post #8 of 40 (permalink) Old 04-22-2011, 01:53 AM
OBS Addict
Up pipe leaks are common. Check then too.
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
post #9 of 40 (permalink) Old 04-22-2011, 04:58 AM Thread Starter
00stroke97
97-BIG RED's Avatar
i checked foe leaks with the soapy water none. i checked my fuel presurre gauge bounces between 50 and 60 psi at idle
post #10 of 40 (permalink) Old 04-22-2011, 01:54 PM
OBS Addict
Ok. Fuel pressure seems good. Did you check your UP-PIPES?
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
Human Verification
