Ford 5th Wheel Prep Package for SB - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 35 (permalink) Old 10-21-2010, 09:43 PM Thread Starter
superduty123's Avatar
With Job2 Ford has released the 5th wheel hitch for the Shortbed
I wanted to add it to my order but the dealer is telling me not to as it is only good if you buy a Ford Specific 5th wheel hitch
I don't have a 5th yet, only thinking about getting one. But the prep package seemed like a good idea with the bracing bar they put underneath
For those of you who do ahve a 5th wheel, or the Long bed with the prep package, is it worth it?
2007 Lariat CC/SB SRW 6.0L 2" Icon Leveling Lift, Rancho 9000 Shocks, Roadmaster Rear Anti Sway Bar, Airlift Airbags with Wireless Remote, Kuhmo 265/70 19.5 with Rickson Wheels, Linex Bedliner
superduty123 is offline
post #2 of 35 (permalink) Old 10-21-2010, 10:06 PM
JimTJr's Avatar
Re: Ford 5th Wheel Prep Package for SB
If your pulling a 5th wheel camper, from what I understand you need a "Slider" hitch to pull one, or chance having your cab damaged when you turn sharply.
As far as the factory setup goes, I heard both ways, that there is a special hitch by Reece for the Ford factory setup, then I have heard that you can buy one that will fit aftermarket. I elected NOT to do the factory setup. For a couple of reasons, First the factory 5er hitch is 1600.00 from Ford and I couldn't get a straight answer about any aftermarket options, also here are 5 holes in the bed with it. The B&W hitch only has ONE hole in the center of the bed. However I don't think the B&W hitch has a slider option, you will need to get one made for short beds. I imagine all the hitch manufacturers have sliders to pick from.
*48* Jim T. 2011 F-350 Lariat, CC, LB, SRW. White Platinum Metallic Tricoat. Black leather seats, I probably wont have*PMS,, with this one, at least no major attacks of it!
JimTJr is offline
post #3 of 35 (permalink) Old 10-22-2010, 12:35 AM
BWilliams's Avatar
Send a message via AIM to BWilliams Send a message via Yahoo to BWilliams
I will look it back up again, but I believe it's only setup for pulling a "Gooseneck" type trailer with the short bed, not a 5th wheel.
Bobby Williams
BWilliams is offline
post #4 of 35 (permalink) Old 10-22-2010, 03:31 AM
JimTJr's Avatar
That may very likely be. I wish they had offered the factory gooseneck option on mine! (Well, kinda wish),,, the B&W is a great choice. I love it in my 03, and am getting one for my '11.
I really wondered if they encouraged 5th wheel hauling with the short bed.
JimTJr is offline
post #5 of 35 (permalink) Old 10-22-2010, 03:56 AM
Diesel Therapist
Greenshield's Avatar
I have been looking at a fiver and have a SB 08. I camp alot and have noticing more SB with 5'ers now than long beds on a regular. I thought you had to have a slider too, but alas I was wrong. I have been looking for an Open Range 5'er and saw one at our last camp stop. I went up to the man who had an 09 f-250 two wheel drive short bed. He was older and after talking for a while found hes has had 4 5'ers. I asked how the SB and he said with the length of the Pin and the shaping of the noses on the trailer, he turns to 88 degrees. He saw the skepticism in my eyes. He invited me back the next day when he planned on pulling off. I came back and dang if he didn't pull an almost right angle with room to spare. The pin box was not an after market lengthened one like I have seen, they are bad as they move the weight too far back. It was factory and the shape of the cone wasn't wierd looking at all. .....now I am a believer.
Greenshield is offline
post #6 of 35 (permalink) Old 10-22-2010, 04:34 AM Thread Starter
On the Ford documentment titled Major Product Changes for the 2011 Superduty dated 10/1/10 it lists under Job 2 Order Guide updates
"5th Wheel/Gooseneck Hitch Pin Prep Package (53W) optional on Lariet and King Ranch"
Is there anyway to verify it WILL handle the 5th???
post #7 of 35 (permalink) Old 10-23-2010, 03:36 PM
JimTJr's Avatar
It will tow it,,but like I said, there could be clearance issues with the cab in tight turns,,,
JimTJr is offline
post #8 of 35 (permalink) Old 10-23-2010, 04:34 PM
RLNCOAL
To clear up any misconceptions.
The FORD 5th wheel only works with the factory prep package and a aftermarket 5th wheel WILL NOT work with the prep package. You can also install the FORD gooseneck along with their 5th wheel. Any new Superduty with the prep package will handle either of the FORD gooseneck and or 5th wheel.
Any time your pulling with a short bed, you'll have to make sure there isn't a lot of over hang on your trailer. If it is close, then you will probably need a slider, which will not work with a Prep package. If you are pulling with a goose and need cab clearance, you're pretty much boned unless you are using a B&W brand gooseneck since they off their extender which gives you an additional 4" of set back.
In all honesty, you are better off going with out the prep package b/c your options are a LOT cheaper. Especially if you ever upgrade your 5er and need a heavier hitch than 16k.
Twotone08 is offline
post #9 of 35 (permalink) Old 10-23-2010, 08:41 PM
BWilliams's Avatar
um, the 5th wheel hitch that is orderable directly from Ford is the Elite Series and is rated for 25,000 lbs.
Bobby Williams
post #10 of 35 (permalink) Old 10-23-2010, 10:27 PM
JimTJr's Avatar
Yes,, but there are CHEAPER, (Not quality wise) options out there. The Ford Prep package is not reasonably priced when you buy the factory option, 370.00, I saw on EBAY the factory GOOSENECK parts are 220.00, and the 5th wheel hitch is 1,600.00!
You can have a B&W, complete, ALL NEW for 1,100 bucks. 399 for the gooseneck, and 799 for the "Companion"
JimTJr is offline
Human Verification
