no interior lights - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-14-2012, 03:11 AM Thread Starter
no interior lights
when i got home from work today i noticed that when i opened the door my interior light and rear cargo light arnt coming on i check all the fuses and not sure what else it could be any ideas?
jdolliver is offline
post #2 of 10 (permalink) Old 09-14-2012, 10:22 AM
Always Smooth
Fudge0514's Avatar
Re: no interior lights
Double check the fuse. I believe its the one that also controls your telescoping feature of your mirrors, as well as the underhood lamp.
2011 F350 Lariat, 6.7L SRW 4x4, Rear E-Locker, spray lined bed, B&W turnover ball, ham radio (VHF/UHF), Snugtop camper shell, ScanGauge II.
1998 AM General HUMMER 6.5L TD
Fudge0514 is offline
post #3 of 10 (permalink) Old 09-14-2012, 10:13 PM
bulbs burnt out?..
PoorMansCat is offline
post #4 of 10 (permalink) Old 09-14-2012, 11:03 PM Thread Starter
bulbs are fine if u manually turn them on they all work my mirror controlls and hood lamp also work.
post #5 of 10 (permalink) Old 09-15-2012, 12:50 AM
Sure there isnt a setting that disables the dome lights on "door open"?? My wifes Mazda has that option that you access on the dash display...
You might try and scan thru the owners manual looking for settings/adjustments???
Other than that, does this issue only arise with the drivers door? Do they come on with the passenger door open?
If its only acting up on one door, I would say theres something wrong with the door latch/switch, if it doenst come on with any door open, would be looking more at a setting or software issue. If you can't figure it out, unhook both batteries for an hour...
post #6 of 10 (permalink) Old 09-15-2012, 01:30 AM Thread Starter
yea light doesnt come on with any of the doors. even when you unlock it with keyless entry cargo and interior are pitch black its hard to see at night when you get into a dark truck.
post #7 of 10 (permalink) Old 09-15-2012, 12:44 PM
sounds like a setting then. My truck has some similar settings that can be programmed, like no interior lights when doors open, Interior light on when unlocking with keyless, headlights on when unlocking with keyless, etc.....
Has the truck always been like this? I would read owners manual carefully and see if it describes the correct procedure for making changes.....
Did you get a chance to disconnect batts.?
post #8 of 10 (permalink) Old 09-15-2012, 07:12 PM Thread Starter
it only started this 4 days ago and havent disconnected batt yet.
post #9 of 10 (permalink) Old 10-15-2012, 05:05 PM
I have that issue in my '08. It quit working after I tried putting in LED's in. I can't even turn the interior lights on using the dash switch. Heard there is some kind module that could have failed because it controls the auto dimming and you can't dim led's. Lights work manually though just like you said
Miguel is offline
post #10 of 10 (permalink) Old 10-16-2012, 01:04 PM
NObama
03sixspeed's Avatar
My lights work perfect after LEDs in the dome lights, and they dim... not sure what's going on with yours like they said check settings I've gone crazy thinking something was wrong before and just had a switch flipped or something.
2010 F-250 CCLB FX-4... Spartan,custom 5" DP back,PS67 DP,Homemade intake,CAC tube,EGR delete,CCV reroute,2.5" Newton,20x10 Revolvers,Timbrens
Originally Posted by Hanging_Heels View Post
Welcome to United States of Obama. Ran by buncha tree hugging, socialist, liberal, hippy, vaginas...
03sixspeed is offline
Human Verification
