Dual battery post terminal and cable replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 01-14-2011, 12:38 AM Thread Starter
I just replaced the passenger side battery in my truck and noticed the cable going from that battery to the other is slightly pulling and corroding from the connector. I searched all over town for a terminal lug that would support the dual wires on the positive side of that battery and can't find anything to work. I'd like to replace the wires with welding wire and keep the gauges reasonable. Right now my starter wire is around a 0/0 ga wire and the battery to battery wire is a 2/0 ga. Did anyone change these and what did you use? How'd you guys work your dual battery wire setups? The factory positive wire from Ford is $210!!!!!! I can build better for less or at least the same price I'm sure if I can find that one terminal post setup.
Thanks
Dave
2003 Fire engine red F350 6.0 CCLB DRW Lariat.
Blue fuel spring, coolant filter, EGR delete, Banjo bolts, Rotella T 5-W40, ARP, DE 4" turbo back, Farmers 175/75's, SCT with Vivian's tunes.
Dave R is offline
post #2 of 7 (permalink) Old 01-14-2011, 12:45 AM
Attention Whore
UNBROKEN's Avatar
Re: Dual battery post terminal and cable replacement
go to a stereo shop for large gauge multi wire terminals. Mine have places for two 0/1 gauge wires plus set screw for 4 smaller wires each.
Spending money I don't have on crap I don't need to impress people I don't know.
UNBROKEN is offline
post #3 of 7 (permalink) Old 01-14-2011, 01:15 AM
7.3 Enthusiast
91turbogsx's Avatar
RockAuto.com has the Ford Motorcraft positive battery cable for $90.89. I have purchased one from them when my terminal on my starter wire broke. It's the whole cable from starter to both batteries.
Just an option...
'02 F-350 4x4 Black RC/LB
4" Lift with 35's. OUO Traction Blocks
20x10 Fuel Throttle's
Lots of deleted parts...
Custom fuel system w/ Strictly Diesel RR
Dieselsite Adrenaline HPOP
DI Up-Pipes
DP-Tuned
and more...
91turbogsx is offline
post #4 of 7 (permalink) Old 01-14-2011, 04:39 PM
All done now
Arisley's Avatar
I got one from O'Reilly's Auto. Had to special order it. Not in the computer, they have to look in the books. $75.00. A lot heavier wire. Perfect fit.
Arisley is offline
post #5 of 7 (permalink) Old 01-14-2011, 05:36 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
which terminals are these Rich? any chance you could send me a pic or just a link to where you got them? Only ones I ever found that I semi liked were the Knuconceptz terminals.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #6 of 7 (permalink) Old 01-14-2011, 11:44 PM Thread Starter
I like the stereo shop idea but I'm sure they're gold plated. Not big on the bling effect but the ability to get one for both batteries and have room for my winch cables is great too. I'll have to look at those online and at the stereo shops.
Thanks
Dave
Dave R is offline
post #7 of 7 (permalink) Old 12-29-2016, 09:42 PM
Just an option...
Ive had to replace my battery cable due to corrosion at the temrinal, and went with the one piece OEM replacement from RockAuto for $89.00. The problem is that my old cable appears to be stuck between the motor mount shield and the engine. Can anyone give me any advice on how to get this cable from between the engine and the shield? For now my truck is stuck in the drive way
Flayologist is offline
Human Verification
