DIY IC Pipe Painting? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-11-2010, 01:54 AM Thread Starter
Myles_S's Avatar
Any of yall painted your IC pipes yourself? What all did you do for prep? How'd you paint it? Clearcoat?
Any thing you can throw out there for me...
Pics are great too
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #2 of 10 (permalink) Old 11-11-2010, 08:40 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: DIY IC Pipe Painting?
everythig but the alt and A/C is in 2100* ceramic paint..very lightly bead blasted..primed with primer made for the ceramic...painted.. then baked in an old cook oven...not seen in the picture but the plenums and pedistal are also done with blue ceramic... the alt and A/C are done in high temp primer then high temp paint..i didnt like the fact it came out darker...ill fix that when the new motor goes in..
Ron's power stroke is offline
post #3 of 10 (permalink) Old 11-11-2010, 09:20 AM
Dennab
Mamba6.4's Avatar
I think the darker looks better anyways :O!
Nice setup
Originally Posted by bigrpowr View Post
"you know i dont know $hit except what i see and read. its just how im built, thats why i ask folks like you the important questions."
Mamba6.4 is offline
post #4 of 10 (permalink) Old 11-21-2010, 01:00 AM
IL7.3 Powerstroker's Avatar
Send a message via Yahoo to IL7.3 Powerstroker
me too!!!!!
2002 F-350 Supercab longbed
AFE intake Bully Dog 5" exhaust
Swamps sticks, DP tuned
IL7.3 Powerstroker is offline
post #5 of 10 (permalink) Old 11-21-2010, 01:32 AM
I just wire wheeled mine and hit them with some rattle can.
2000 F-350 ccsb 4x4: DIY intake, 4 inch straight, Tuning by Matt@Gearhead---Sold
99 tacoma V6 5sp 4x4: Chaos/DR mid travel kit, F/R glass, 33x12.50 MTR's---Sold
08 F-150 Lariat Screw 4x4:---Sold
2005 F-250 Lariat ccsb 4x4 auto: All stock for now
Stroke00 is offline
post #6 of 10 (permalink) Old 11-21-2010, 04:22 AM
All done now
Arisley's Avatar
Mine is just rattle canned also. Wire wheel, wiped down with acetone. About ten coats.
Installed with dirty hands, went through a heat cycle or three, grease marks live there now.
Arisley is offline
post #7 of 10 (permalink) Old 11-21-2010, 05:09 AM
TARM's Avatar
What caused the difference in the color shade? Primer change?
Was this stuff in a spray can or did you use a real sprayer? Can you give some more details on it all?
I have a whole turbo kit turbo dual HPOP etc all here I am getting ready to install and would love to spray it all like that. I too actually like the darker shade but woudl likely want to try and be close to ford blue.
Looks like my blast cabinet and parts cleaner tank will be getting some more work soon.
TARM is offline
post #8 of 10 (permalink) Old 11-21-2010, 07:05 AM
sounds like you got some fun mod's going in..congrats..the ford blue i bead blasted very lightly, primed with high heat primer then sprayed very thin layers of ceramic with a gun..a friend of mine that works at a body shop got me the primer and ceramic paint...i see it in rattle cans as well...not sure if its the same or not...its been posted here but i cant remember what the 3 letters where..EHV maybe?? (ill look for the name after work). then after about an hour of drying time..I baked the pipes in an old cook oven i had for 30 minutes at 250* then take them out to cool for 30 minutes then again in the oven to 400* for 30 min and cool for 30 again..back to the oven set at 600* for 30 min and cool again for 30 min..I used the direction for the ceramic but did a second bake at 600* just because I wanted to... ill tell ya what..this stuff is rock hard when its baked...I can see why it holds up....i did the alt and A/C a week or two before i did the rest..it is high heat paint and was from a rattle can..i like that blue as well but could not get ceramic to match up...
post #9 of 10 (permalink) Old 11-21-2010, 08:00 AM
TARM's Avatar
Cool yeh I have taken some time to put a whole list of upgrades together to do all at once. I figured if I was gonna have everything torn apart I might as well do it all at once.
What is great is I can do things like the AC, PW steering, alt as I have time. I have a old spray gun but have never used one in my life. I think I will go the rattle can route and do really light coats to keep it smooth.
Will do the valve cover as well since I will be all in there.
TARM is offline
post #10 of 10 (permalink) Old 11-22-2010, 03:52 PM
You might consider doing a soundproofing coating on the valve covers instead of just a decorative coating. I think others have had decent results in quieting the engine noise when using a coating on the valve covers. Just a thought as long as you're that far into the engine.
bill4d is offline
Human Verification
