F650 dash mod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 64 (permalink) Old 10-23-2008, 02:42 PM Thread Starter
MAXIMUS OVERDRIVE
BDRUMMONDS's Avatar
F650 dash mod
O.K. guys and gals, here are the final pics. I installed the 6 Carling switches, and a DPDT (on-off-on) rocker for my temp guage. After I had cut the opening to fit the 2 carling 3 switch mounts, I had about 1.5 inches of open space at the bottom that just didnt look right to me. I added a false back to the opening and then filled it with bondo. I then hit it with a 100 grit sanding block to get it all nice and level, and then finished it off with 320 grit sand. I light coat of primer, and some paint and its done.
The rocker switch you see below the main switches is a selector switch for my temp guage. Throw the switch to the left, and my guage reads my oil temp, throw it to the right and it reads my coolant temp. I added a T fitting to my HPOP resevior to accomodate both the factory EOT sensor, and the sensor that came with my guage. I also added a sensor for coolant temp in the same fashion. Before anyone asks, I had to add the T fitting to my waterpump, simply because the inside of the hex plug was chewed up, and would not come out.
sorry the nighttime pics arent that clear, cheap camera.
I still need to remount my brake controller
Ford Part number is 4C4Z-7004302-BA, It was about $60 from my local medium duty dealer.
The panels come in the dark gray color of the top half of my dash, but since I was transfering my cup thrower, and ash tray over I went ahead and painted mine to match.
99.5 F250 4X4 CC SB isspros,DP, FASS pump, fuel bowl delete,SSHPX,OBA, 6.0 IC, 1.15 van turbo,ATS ported housing ,etc...
it goes and shows well for 320K
BDRUMMONDS is offline
post #2 of 64 (permalink) Old 10-23-2008, 04:27 PM
farmboy930's Avatar
Re: F650 dash mod
very nice!!!
2000 F250 CC SB Auto
Silverline 304ss TB AFE stage 2
DiPricol Optix Gauges Boost, Pyro
Elite Diesel XCAL2 tow power, high power, max power
EARLY99 F350 REG CAB AUTO
Farmers custom exhaust & intake
Edge Juice w/ Attitude
farmboy930 is offline
post #3 of 64 (permalink) Old 10-23-2008, 04:46 PM
I love you bigrpowr!
QtrHorse's Avatar
Re: F650 dash mod
That is very nice. I wonder if this would work with a manual truck, with that extended part being there? I like the switch mounting, nice job.
I assume it does not come with the ashtray and the cup holder? If not, what year of ashtray will fit? My ashtray out of my 99.5 does not look like that. I do have the updated cup holder already.
99.5 F250 XLT S/C 6SPD
I have no ring and no love from the mods.
QtrHorse is offline
post #4 of 64 (permalink) Old 10-23-2008, 05:00 PM
Layson's Avatar
Re: F650 dash mod
Yeah that looks nice!
Layson is offline
post #5 of 64 (permalink) Old 10-23-2008, 05:33 PM
PSN Mega Miler
crowz's Avatar
Re: F650 dash mod
Looks tough !! I like.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #6 of 64 (permalink) Old 10-23-2008, 06:10 PM
Sofa King Cool
BMac's Avatar
Send a message via AIM to BMac Send a message via MSN to BMac Send a message via Skype™ to BMac
Re: F650 dash mod
that looks awesome!
People Fly Airplanes, Pilot's Fly Helicopters
2002 F350 Extended Cab Shortbed
1977 Early Bronco
BMac is offline
post #7 of 64 (permalink) Old 10-23-2008, 07:04 PM
fbilly420's Avatar
Re: F650 dash mod
that looks great
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #8 of 64 (permalink) Old 10-23-2008, 07:29 PM Thread Starter
MAXIMUS OVERDRIVE
BDRUMMONDS's Avatar
Re: F650 dash mod
Nope, wont work for the handshakers. The precut rectangular hole is used to house the push button tranny controller for the 650. there is also another small hole that is precut (under where my voltmeter is), it would be used for the parking air brakeknob. I just enlarged it to fit the guages I had. In the next month or so I will be getting some Isspros to match my pillar guages.
You're correct the cupthrower and ash tray do not come with the panel. My truck is a 99.5 so your ashtray should look like mine. All the mounting holes line up perfectly.
I only had to enlarge the large rectangular opening about 1/4 on each side to accomodate the switch housings.
Thanks for the kind words guys.
post #9 of 64 (permalink) Old 10-23-2008, 08:58 PM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
Re: F650 dash mod
That is badass, especially with the swichable temp gauge! Nice work.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #10 of 64 (permalink) Old 10-23-2008, 09:41 PM
Back to Civilian Life!!
MILFORD's Avatar
Re: F650 dash mod
Thats sweet I want to do something like that. Freakin awesome
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
Human Verification
