diy ebpv delete - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 36 (permalink) Old 05-29-2010, 03:16 PM Thread Starter
diy ebpv delete
has anyone ever come acroos a write or kit to delete the ebpv out of the stock turbo? it looks like you could pull out the flap and put a freeze pleg or somethin in the bottom side... very high temp area so it would have to be stout
any thoughts
broncbeast is offline
post #2 of 36 (permalink) Old 05-29-2010, 03:19 PM Thread Starter
Re: diy ebpv delete
wow.. wrote that kinda fast....i promise im a fart smella...uh i mean smart fella
"..write up.." "..freeze plug.."
post #3 of 36 (permalink) Old 05-29-2010, 03:22 PM
7.3powerstroke03's Avatar
Send a message via Yahoo to 7.3powerstroke03
Re: diy ebpv delete
thats what i did on mine is pull the flap and rod out and put plug on bottom side, also i unplugged the ebpv actuator so that it would not cycle when cold
2000 F250 reg cab 4x4 6spd 270k
7.3powerstroke03 is offline
post #4 of 36 (permalink) Old 05-30-2010, 02:36 AM
tneibling's Avatar
Re: diy ebpv delete
I'm also planning to delete mine soon because mine leaks lots of oil when it's cold and the ebpv is in use
tneibling is offline
post #5 of 36 (permalink) Old 05-30-2010, 05:05 AM
Canadian Stroker
doubledoor's Avatar
Re: diy ebpv delete
Put on a blank turbo pedastal and a blank exhaust outlet and you will never have to worry about it again. Like frost plugs falling out when it gets hot or threads leaking where you plug it.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #6 of 36 (permalink) Old 05-30-2010, 12:46 PM
Rented Mule
icanski2's Avatar
Re: diy ebpv delete
If you gut the EBV and drive freeze plugs in the shaft holes, drive the freeze plug deep in the hole and to install an internal snap ring in the grove. This will hold the plug in. I did mine about 8 years ago and I had one plug come out after my first install and I never had a problem after installing a snap ring. I canít remember the freeze plug size but I know it was metric and a very tight fit.
When you gut the valve, do yourself a favor and just buy a non-EBV turbo pedestal now if you plan on keeping your truck a while. You can find one for around $100 if you search a little. I gutted several turbo pedestals a few years ago and they all work fine, but they can be prone to leaks around the plug where the actuator rod was. Whatever you decide to do, I wouldn't recommend just leaving the actuator rod hanging out of the pedestal because it will start leaking in a short amount of time. I now use my gutted pedestal as a wheel chock for my Polaris Ranger because I'm too lazy to fix the emergency brake.
My 7.3 doesn't leak oil. It marks my space!
Y2K F250 Lariat CC 4X4, Bought New
TS/BTS 4 POS and a 6 POS w/ Beans tunes
Adrenaline, ARP Head Studs. 910's. DI Push Rods
Beans 250/100's, BTS, 6.0 Cooler, Walbro
AFE Stage II, GT38R - Dieselsite Ported
Non EBV Pedestal, ITP R.R. Fuel Sys, CCV Mod
DPP 4" Exhaust, Isspros, DiPricol HP Oil Gauge
icanski2 is offline
post #7 of 36 (permalink) Old 05-31-2010, 03:28 PM Thread Starter
Re: diy ebpv delete
wow great tips guys...thank you, i knew there was a d-i-y way...
post #8 of 36 (permalink) Old 05-31-2010, 07:45 PM
Homesteader's Avatar
Re: diy ebpv delete
By doing the EBV delete does that just prevents future exhaust leaks?
Homesteader is offline
post #9 of 36 (permalink) Old 06-03-2010, 01:13 AM Thread Starter
Re: diy ebpv delete
what it does is remove the flap in the exhaust side of the turbo that ins hydraulically actuated closed ,when the engine is cold and then opens up as the motor gets hot. it looks just like the throttle plates on a topfuel dragster. i live in louisiana and rarely have cold mornings so i dont think it will affect me much if it is removed. but what it does do is give u about 10-15% more flow outta the turbo
post #10 of 36 (permalink) Old 06-03-2010, 02:08 AM
Re: diy ebpv delete
Hi ---
Was wondering I was told you could just disconnect it at the pedestal by pulling the plug... Does that work? Or did I fall for someones internet mods
2000 F 350 SD,4 door XLT Dually 197,000 7.3 Liter V8 Powerstroke
DIY Tymar air intake/ Foil Delete/ Wicked Wheel/ AIH Delete/Stancor GPR /Boost,Pyro,Tranny Gauges
Trucool Tranny Cooler
birdog is offline
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/14-7-3l-power-stroke-aftermarket-performance/63210-diy-ebpv-delete.html
Posted By For Type Date
Turbo pedastol - Diesel Forum - TheDieselStop.com This thread Pingback 10-27-2015 11:06 PM
