removing the exhaust back pressure valve??? - Page 4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #31 of 67 (permalink) Old 06-16-2010, 02:49 AM
Re: removing the exhaust back pressure valve???
Im sorry i sound like a broking records but can someone tell me where it is located.
97 f350
fpr mod, diy intake, zf5 tranny, 230k miles alot more mods to follow
Mr Goodtime
97 chevy 2500
5 ton running gear 40 inchs of lift on 54's ya its big but fun
2wd_sled_puller is offline
post #32 of 67 (permalink) Old 06-16-2010, 02:54 AM
roughneck0913's Avatar
i would delete the ebpv accuator remove it like i stated in a couple posts up drill and tap the hole the rod was in and put a pipe plug in it remove the metal shavings put the aluminum plug back in with snap ring. or build a plate and weld the big hole closed your choice or buy a non ebpv pedistal put new orings under pedistal install pedistal put new orings in for turbo install turbo and walla ebpv delete done
Sold---2000 f-250 4x4 cclb 6 pos tuned by cale airdog 250, holding a stock tranny. afe cold air few other tricks under the hood always
2008 F-250 CCSB 4x4 ZF-6 deleted from day 3
roughneck0913 is offline
post #33 of 67 (permalink) Old 06-16-2010, 02:55 AM
where what is located?
post #34 of 67 (permalink) Old 06-17-2010, 12:08 AM Thread Starter
DIESEL DAN's Avatar
WHAT DO I DO ABOUT THE ROD??? DO I JUST LEAVE IT HANGING DOWN???
Early 99'(10/18/98)f-250,4x2,Super Cab XLT 8' Bed
MBRP 4" Turbo Back
Swamp's Diesel IDM
Grover 1700 Single Trombone Air Horn
Coolant filter Bypass W/ Napa Gold #4070 Filter
Air Intake W/CCV Mod,V-10 Trans Cooler
Stewart Warner Gauges: Trans,Pyro,Boost,
20% Window Tint
Retro Solutions 55 watt HID's 5000k
08' Super Duty Finned Diff Cover
DIESEL DAN is offline
post #35 of 67 (permalink) Old 06-17-2010, 12:16 AM
Slated4Greatness's Avatar
If you just buzz the rivets off and leave the shaft you don't have to worry about closing up the hole or what to do with the arm.
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #36 of 67 (permalink) Old 06-17-2010, 01:16 AM
Work in progress
opieg01's Avatar
marty has a video. Google works wonders
2001 F-250 4X4 LARIAT Crew Cab,7.3, ZF6
GTX-4294r, Swamps 300/200%
couple other bolt ons
opieg01 is offline
post #37 of 67 (permalink) Old 06-17-2010, 02:25 PM
dinnerbooter treasurer
genuineford's Avatar
When I delete them I take the pedestal off and remove the snap ring from the back and take the guts out of the actuator. Then i drill the hole and tap it to accept a 1/4 inch npt plug. Otherwise you run the chance of it leaking. The other option is to buy a non ebv pedestal.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #38 of 67 (permalink) Old 06-17-2010, 06:53 PM Thread Starter
DIESEL DAN's Avatar
I'm i gonna have to replace the o-rings than? how do i remove the pedestal?
sorry, i'm new to all this!
MBRP 4" Turbo Back
Swamp's Diesel IDM
20% Window Tint
post #39 of 67 (permalink) Old 06-17-2010, 06:59 PM Thread Starter
DIESEL DAN's Avatar
i also just found this. is it true??? or is it ok to plug without ANY problems?
OEM
Email this to a friend
OEM Non-EBV Pedestal - Early '99 Ford Powerstroke (PRE 12/98)
FREE WITH ORDER: Two sets of o-rings (upper and lower) included for installation
YOUR COST: Qty
$135.00
Personalization
Check here to confirm there are no returns on this item. (Required)
Detailed Description
This is the Non-EBV pedestal for the Pre- 12/1998 7.3L Ford Powerstroke.
If you have removed your backpressure valve EBV from the outlet of the turbo, you need this pedestal.
Q. If I disconnect the sensor, some say this will throw a code ,so they remove the turbo, cut the actuator rod off, and tap the hole in the pedestal and put a plug in it with the sensor still plugged. Is this "ok" to do?
A. If you simply plug the hole and leave the sensor plugged in, you may cause yourself the loss of a turbo from lack of oil flow. Let me explain. The same feed port that feeds the turbo bearing is feeding the EBV piston. There is one supply port and one return port in the pedestal. When the EBP sensor sends the signal to the pedestal to shut the valve,which is not there in this case, the oil dumps off to the return port in the pedestal with no resistance. This is the same return port as the one for the turbo. The piston separated the two when it is was properly used from the factory. Basically, while the valve is being actuated or attempted to in your case the turbo gets no oil or very little. The turbo bearing is the highest place in the engine for oil to travel and it will follow the path of least resistance. If you remove this piston in the pedestal, you MUST not allow computer control of the valve any longer. You must disconnect the sensor from the pedestal. Yes, you will get a code (not a light) telling you the valve is non-operational, but it's the only way to do it.
THERE IS NO CORE CHARGE ON THIS ITEM.
MBRP 4" Turbo Back
Swamp's Diesel IDM
20% Window Tint
post #40 of 67 (permalink) Old 06-17-2010, 10:36 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
both will do the job..i moded mine with a stock turbo then went with a deleted kit when i got my 38R...the only diff's is the bolt head sticks out in your's.. and the already deleted one has none...i moded my stocker cause it leaked and a kit didnt fix it...IMO if mine didnt leak..i wouldnt mod it...a new one is big bucks...you could sell your's later to cover the cost of a new deleted one...there are people out there (like craige list) that run these trucks and believe these need to be in place...
Ron's power stroke is offline
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/14-7-3l-power-stroke-aftermarket-performance/56900-removing-exhaust-back-pressure-valve.html
Posted By For Type Date
7.3 Exhaust Pressure Control Valve_Yaelp Search This thread Refback 11-07-2015 11:41 PM
