Quick ? About EBPV Delete - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-09-2017, 10:38 PM Thread Starter
If I leave the sensor/actuator on the front of the pedestal unplugged will it throw a code??
997.3f250 is offline
post #2 of 6 (permalink) Old 01-09-2017, 11:42 PM
Soft code I believe, RiffRaff has a delete plug for it.
1995 Crewcab XLT 4x4 7.3, E4OD, 3.55, TS 6 chip, RiffRaff air filter.
Whoknows is offline
post #3 of 6 (permalink) Old 01-09-2017, 11:54 PM Thread Starter
Re: Quick ? About EBPV Delete
I installed the new pedestal w/o the sensor/actuator so I will not need the plug. So just tie the wire out of the way and it's all good? Will it give a check Engine Light??
post #4 of 6 (permalink) Old 01-10-2017, 03:28 AM
Moderator
Sbluke55's Avatar
It sets a soft code. Meaning no check engine light but when you pull codes it will show up.
01 f-250, Standard
Sbluke55 is offline
post #5 of 6 (permalink) Old 01-10-2017, 10:59 AM
Luddite in Charge
Mr_Andy's Avatar
I've always gone with a delete pedestal and just zip tied the plugged in unit out of the way. Let it think it's doing something.
Mr_Andy is offline
post #6 of 6 (permalink) Old 01-10-2017, 02:20 PM Thread Starter
Sounds good. I was thinking of leaving it plugged in to the to that unit. I think that's what Ill do. Thanks to everyone for your input.
Human Verification
