Size difference. stock vs gt38r - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 20 (permalink) Old 01-18-2010, 03:07 PM
Caption This
444-4D's Avatar
Re: Size difference. stock vs gt38r
Originally Posted by Deputydog View Post
stock turbo has a 62mm compressor wheel and an 80 mm exhaust.
The 38R has a 66mm/88mm..
You are confused.
The stock compressor wheel exducer is 80mm and the inducer is 59.87mm (56trim).
The 38r compressor wheel exducer is 88mm and the inducer is 65.86mm (56 trim).
The turbine wheel on both turbos has a 76.20mm inducer and a 67.73mm exducer (79 trim).
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #12 of 20 (permalink) Old 01-18-2010, 03:59 PM
Snake Oil Salesman
mattr66's Avatar
Originally Posted by 444-4D View Post
You are confused.
hey what are the specs on the van turbine again?
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #13 of 20 (permalink) Old 01-18-2010, 04:02 PM
Caption This
444-4D's Avatar
76.2mm inducer and a 69.84mm exducer (84 trim).
444-4D is offline
post #14 of 20 (permalink) Old 01-18-2010, 04:05 PM
Snake Oil Salesman
mattr66's Avatar
They should have used that wheel on the 38r.....
Matt Robinson
mattr66 is offline
post #15 of 20 (permalink) Old 01-18-2010, 04:34 PM
<-- it's like that
Where did you find those turbine wheel specs, 444? I've looked before and never found them. I'm not doubting you, just I haven't seen them published before. It's good info to have handy for those who ask.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #16 of 20 (permalink) Old 01-18-2010, 05:29 PM
Caption This
444-4D's Avatar
I have them written down.
All of the 7.3l turbos fall into the GTP38 (pre-'98 were TP38) model range. This is a frame size that was created just for the Powerstroke engine, and is reverse rotation. Turbine wheel inducer (larger diameter) size is 76.2mm. This puts it right between the standard GT37 and GT40 frame sizes. This makes it just a bit larger than a T04.
Main differences between the GTP38 truck turbo and van turbo is that the turbine wheel trim (smaller diameter squared/larger diameter squared) is larger on the van turbo (84 vs. 79) and the van turbo was supplied with a 1.15A/r non-wastegated turbine housing vs. the 0.84 wastegated housing on the truck turbo. Because of the difference in turbine wheel trim, the housings are not interchangeable.
That is a quote from beanbooger on TDS several years ago. He was the Garrett Engineer that developed the 38r. I have also measured the wheels since then.
444-4D is offline
post #17 of 20 (permalink) Old 01-18-2010, 08:58 PM
<-- it's like that
Awesome. Thanks for posting that!
Curtis
2002 F-250 PSD
Pocket is offline
post #18 of 20 (permalink) Old 01-19-2010, 02:53 AM
PSD addict
What does the trim mean??I am still learning so go easy on me.
Is it the angle at witch the blade is at.Less trim the flatter the blade lays,the more trim the higher the angle of the blade?
Beanhead is offline
post #19 of 20 (permalink) Old 01-19-2010, 02:58 AM
Caption This
444-4D's Avatar
TurboByGarrett.com - Turbo Tech102
444-4D is offline
post #20 of 20 (permalink) Old 01-19-2010, 03:03 AM
PSD addict
Thank you very much!
I have some reading to do.
Beanhead is offline
Human Verification
