Question about map sensor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-29-2009, 02:56 AM Thread Starter
I have a 99.5 7.3L Powerstroke. For the past 2-3 weeks, I have been experiencing significant power loss and MPGs. I have regulated fuel return, DIY Tymar intake, muffler delete. I have replaced all the o-rings in the turbo, checked manifold connections, all ductwork connections. I have fresh oil, fresh fuel filters, so now I am thinking possible map sensor. I'm not quite sure how to test the map sensor. I put my volt meter test leads on the wires with the connector plugged in, I was getting 5 volts at an idle. This seems way too high, but I'm not sure. Any suggestions?
dadto4boys is offline
post #2 of 10 (permalink) Old 10-29-2009, 02:59 AM
POWERSTROKER's Avatar
Re: Question about map sensor
Whats your fuel pressure?
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #3 of 10 (permalink) Old 10-30-2009, 12:12 AM Thread Starter
65psi.
post #4 of 10 (permalink) Old 10-30-2009, 06:45 PM
fbilly420's Avatar
Do you have gauges? If so how much boost are you seeing? Do you see any soot around any of the exhaust connections before the turbo?
How are your brakes? If you have a brake or park brake hanging up that will really kill fuel mileage.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #5 of 10 (permalink) Old 10-30-2009, 06:59 PM Thread Starter
ive checked for leaks evryware i can think of i need to get gauges i was also thinking about wastgate is there a way to check this with out gauges
this is my first diesel thanks for the help
post #6 of 10 (permalink) Old 10-30-2009, 07:05 PM Thread Starter
i have also checked brakes dont seem to be hanging up
post #7 of 10 (permalink) Old 10-30-2009, 07:09 PM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Unplug the redline and plug the redline and see if your boost #s change or if they just get there quicker.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #8 of 10 (permalink) Old 10-30-2009, 11:16 PM Thread Starter
ok i went to the local parts store and got a boost gauge i tapped the manifold right below the map line the gauge read no boost even under throttle
unhooked and pluged wastgate line slill nothing i took the map line off and could feel some pressure but i had to put it right to my face before i could feel it
post #9 of 10 (permalink) Old 10-31-2009, 10:00 AM
Were you actually driving the truck or sitting in nuetral at full throttle? If just sitting reving it up, you will not be able to acheive boost.
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
post #10 of 10 (permalink) Old 10-31-2009, 03:49 PM Thread Starter
I did put in in drive, and hold on the brakes and rev it up, but I did not drive down the road. I figured this would achieve a load on the engine. Tomorrow I am going to clean my EBPV tube and sensor, if this is clogged, could this cause no boost?
Human Verification
