Disconnecting Wastegate OK? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 08-20-2009, 05:24 AM Thread Starter
Phiber Optik's Avatar
So I have a problem with low boost on my 38r turbo, before I start adjusting the wastegate rod can I take the c-clip off and pull the rod end off the pin and take it for a quick rip to see how much boost it will make with the wastegate staying closed? Or is that a big no-no?
Thanks, Jon
2008 F-350 CC SB Lariat, 4wd, 20x12, 35x14.5, 4" lift w/ Bags, 4" Exhaust, IC Pipe, Elbow, S&B Intake, EGR Delete, Gearhead Tunes, Hellwig Sways, Recon Ltng
2000 Corvette - JT Trim Vortech
2007 HusaberG FS650
2008 RZR - Z1 Turbo
Phiber Optik is offline
post #2 of 18 (permalink) Old 08-20-2009, 05:31 AM
Re: Disconnecting Wastegate OK?
just unplug the red line going to the wastgate actuator. same effect, less hastle
PMRCM#1
slowleak is offline
post #3 of 18 (permalink) Old 08-20-2009, 05:34 AM
Snake Oil Salesman
mattr66's Avatar
how much boost are you seeing?
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #4 of 18 (permalink) Old 08-20-2009, 05:50 AM Thread Starter
I don't belive it is the same thing, the wastegate is spring loaded and still opens if the pressure is reached without the red line to open it earlier
max 15lbs right now, had over 30 with stocker with the same tuning
2007 HusaberG FS650
2008 RZR - Z1 Turbo
post #5 of 18 (permalink) Old 08-20-2009, 06:05 AM
Layson's Avatar
It won't see any boost if that line isn't hooked up... unless you have a turbomaster wastegate controller... or something similar..
Layson is offline
post #6 of 18 (permalink) Old 08-20-2009, 06:09 AM Thread Starter
you're saying if you disconnect the rod from the exh housing the wastegate will be left open? Makes sense as the spring holding it closed is in the diaphram
2007 HusaberG FS650
2008 RZR - Z1 Turbo
post #7 of 18 (permalink) Old 08-20-2009, 01:22 PM
Lovin the Tuna
RedSmokey's Avatar
did you check for boost or uppipe leaks?
2001 F250
2000 F250
RedSmokey is offline
post #8 of 18 (permalink) Old 08-20-2009, 01:34 PM
Banning Smut
PTSUPERD's Avatar
Disconnected red line on mine for like 7 years. 28-30 psi with stock injectors....40-42 psi with hybrids. No issues for me.
PTSUPERD is offline
post #9 of 18 (permalink) Old 08-20-2009, 01:39 PM
FREE THINKER
Chip's Avatar
What do you think about disconecting it on a stock turbo with tunes?
1999 7.3, 2wd ,auto
Chip is offline
post #10 of 18 (permalink) Old 08-20-2009, 01:43 PM
01platinum's Avatar
You'll be fine. Was pushing 14 psi with mine before unplugged the red line and now at 26-28 psi.
Real Diesels Have Stacks
New Tunes by Matt @ Gear Head - Auto Meter Gauges from Nate @ PTP
Air Dog II Fuel Pump
First RR Fuel System built by hand @ Murff Racing
More to come soon..........
01platinum is offline
Human Verification
