2001 F250 7.3L upgrade recommendations - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 06-07-2009, 07:54 PM Thread Starter
I'm confused! I'm having a hard time finding reliable recommendations on how to upgrade my 2001 F250 for both fuel economy & performance. I use the truck mostly for support & company promotion on dirt/gravel roads & highway - no sled pulling, lite towing, and no racing.
I've added a 4" turbo-back straight pipe exhaust, AirRaid intake, Fitch Fuel Cat, DP Tuner F5 (thinking of swapping for F6), 8" lift, traction bars, 38's, dual Yellow-top Optima batteries, 430 gears, performance transmission, John Wood VB, diff covers, Zmax (will try Schaeffers soon), Royal Purple gear oil, tire balnce beads, ...
I'm not happy with my open AirRaid system and am looking to change to S&B or AFE Stage 2.
My turbo seems to surge under heavy towing or spinning. Am now looking at ATS housing or Wicked Wheel or GTP38R BB Turbo upgrade.
Am looking at replacing intercooler with Banks or other as well.
Shopping for dual ram air hood replacement but having no luck finding low enough price.
Would like to switch to Kelderman suspension for smoother ride & higher lift but too expensive.
Researching Painless Water/Meth system.
Have been recommended to upgrade to Terminator? HPOP & DD bigger injectors.
Need to upgrade steering if go to 40"+ tires.
I'm torn between going bigger (tires/lift), performance, fuel economy, and off-roading. I mostly like the high riding trucks but that screws my mpg. And the more street/show upgrades make it less off-road capable or too expensive to trash. So many choices with so little money.
Thanks ahead of time for your help.
kcrowe is offline
post #2 of 9 (permalink) Old 06-07-2009, 08:02 PM
Re: 2001 F250 7.3L upgrade recommendations
Take the silly lift off of it...
2001 F-250 4x4 Crew shortbox, Optix gauges, DP F5 60towHighAlt, 80E, 100, 120. WW, ITP Boost Annihilator. DIY 6637 intake.
redmist is offline
post #3 of 9 (permalink) Old 06-08-2009, 05:21 PM
<-- GO BRONCOS
dblamp's Avatar
Big tires and a 8" lift will kill both mileage and performance.
Save and get the Garrett 38R.
Stay away from the meth, and use the water to controll EGTs.
Seeing that you have a 2001, you probably have PMRs (powered metal rods), which have been known to fail at over 400hp, so check if you have those before going with big injectors.
How can I tell if I have forged rods? - Powerstroke Nation
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #4 of 9 (permalink) Old 06-08-2009, 05:24 PM
Lovin the Tuna
RedSmokey's Avatar
id go with a 38r, stay away from meth, and you might not even need the water or innercooler after getting the 38r...
2001 F250
2000 F250
RedSmokey is offline
post #5 of 9 (permalink) Old 06-09-2009, 06:40 PM
South Atlanta white trash
Doodie's Avatar
run a hood stack...
Garmon's Diesel Performance
SOLD...
01' F250 CC 7.3
16.5:1, Mahle's .0050 with harden forged, 37 deg. valve job, Comp 910's, 4130 pushrods, Mac/K&N
H-11 studs, HT turbo, DP tuned, Bean's injectors/plentums, DI's fuel system
Built trans with Red Altos/PI triple disc.
2010 CC 6.4, 6" lift, 20's & 35's
Doodie is offline
post #6 of 9 (permalink) Old 06-09-2009, 07:08 PM
Location: I live in hendersonville TN right now but visit my home in Ms alot also
read on here no need to waste ur money on intercooler upgrade. Go with the 38r, and if you wanted extra cooling just water no meth.
Lift is big enough and what mpg's are you getting?
MSdiesel83 is offline
post #7 of 9 (permalink) Old 06-09-2009, 08:33 PM
HP Junky
I'd shy away from the Painless Water kit. There is nothing painless about that install :doh
Way easier kits to install out there, Snow Performance or Cooling Mist
RockinJW is offline
post #8 of 9 (permalink) Old 06-10-2009, 02:01 PM
userma3648's Avatar
08 6.4 with some goodies
userma3648 is offline
post #9 of 9 (permalink) Old 06-15-2009, 04:18 PM
WitH A QuicKnesS!!
DI-Tommy's Avatar
dont use the water meth, bad idea...we at DI sell our intercooler if your interested in one, you can PM me, the 38R will help you alot more than a housing and wheel, i mean its just worth the money to do the upgrade. and the AFE stg 2 with the PG7 will help you alot, seeing as how you use the truck in dusty conditions.
^v^v^v^v^v^v^
DI-Tommy is offline
Human Verification
