ATS ported turbo housing - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 16 (permalink) Old 08-13-2013, 01:16 AM Thread Starter
hunter scar's Avatar
Hey was wondering if anyone was running one on their 7.3L? How hard is the install and is their any performance gain other then stopping turbo surge? Thanks Hunter
1997 f250 ex cab short bed 4x4, 5 speed, tymar intake, 3inch mbrp downpipe to 5inch straight pipe, 2inch rough country front add a leafs. more to come. Totaled
2002 f250 ex cab short bed 4x4, 6 speed, tymar intake, 4inch downpipe to 5inch strightpipe, leveling kit ,issapro ev2 boost and pyro, PHP Hydra
hunter scar is offline
post #2 of 16 (permalink) Old 08-13-2013, 01:52 AM
mtray's Avatar
Re: ATS ported turbo housing
I have the USA housing and the install was very easy, just dont lose that c clip where the wastegate rod connects to exhaust housing. no other performance gains, whistle is a little more prominent but thats about the only difference besides stopping the surge.
2000 Ford F250 7.3 4x4. MODS: Beans Tunes, Jegs 4" exhaust, S&B intake, boost fooler, USA poted housing, RR billet wheel for ported housing, HFO, glowshifts 3-in-1 gauge pyro, boost, trans. AIH delete, bellowed uppipes, Sinister Diesel coolant filter.
mtray is offline
post #3 of 16 (permalink) Old 08-13-2013, 04:20 AM
Billet compressor wheel will stop surge and give you performance gains.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #4 of 16 (permalink) Old 08-13-2013, 04:47 AM
mtray's Avatar
that it will..and its about 200 bucks cheaper
mtray is offline
post #5 of 16 (permalink) Old 08-13-2013, 05:44 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
ATS or other housings do one thing only...
Fix Surge...
The new compressor wheels improve performance and stop surge in 99% of cases...
Riffraff Diesel: Riffraff Diesel Billet Compressor Wheel 94-03
01 F-250 SC PSD,280k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #6 of 16 (permalink) Old 08-13-2013, 07:57 AM
hyrk's Avatar
or here, check out the write up at this link:
NEW BILLET WW2 - WICKED WHEEL 2 with FREE PEDESTAL O-RINGS
2002 F-350, S&B intake, 38R tubro w/ wwII, EBV delete, CFM manifold, Spearco i/c, Adrenaline HPOP, Casserly stage I AC injectors , ITP Reg. return, DI Headers, hutch fuel mod, Cooling mist stg. 3, 4" MBRP Exhaust, transflow 46 and 40 gal fuel tanks/tool chest, Tunes by GAP, 4" pc lift, 22" Tis 534 wheels w/37"x 13.5" Dakar MT's, 4.30 gears
hyrk is offline
post #7 of 16 (permalink) Old 08-13-2013, 04:05 PM
Village Idiot
southmike's Avatar
the first generation wheels actually lost some boost when used with the ats housing.
have not herd the combo of the two with the newer wheels but imagine you would have less surge but less peak boost. no one has really commented on that.
my e99 has the original wheel so I have never seen surge on my truck..now if you get larger injectors I have heard an e99 will surge. not sure if that is the same for a 99.5+ superduty as I have not seen anyone says my truck still surges with the new wheel.
southmike is offline
post #8 of 16 (permalink) Old 08-13-2013, 10:42 PM Thread Starter
Thanks for the info guys! Do you have to pull the turbo to install the ww2 or is their a way you can do it and leave it on the truck?
post #9 of 16 (permalink) Old 08-13-2013, 10:53 PM
jbrixen's Avatar
if you want to leave it on. move the down pipe, use a screw driver wrapped in a shop rag or something to hold the fins while you loosen the comp wheel.
safest bet is to just pull the turbo, but i have done it both ways.
jbrixen is offline
post #10 of 16 (permalink) Old 08-14-2013, 01:11 AM Thread Starter
Ok is it hard to hold the fins like that?
Closed Thread
Human Verification
