Which wastegate actuator is better for the 7.3? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 01-07-2009, 05:00 AM Thread Starter
Member
Ok i have been searching around and have been reading info on different companys that make aftermarket wastegate actuators, and i think i found the one i like the most... The Banks Big Head, but idk if its the best or if it will work well on my 7.3?
2004 F-250 XL 6.0L Powerstroke 6 speed 4x4
2001 F-250 XLT 7.3L Powerstroke Auto 4x4
1990 F-350 Lariat 7.3L IDI 5 speed 4x4
01'blackwidow is offline
post #2 of 30 (permalink) Old 01-07-2009, 06:29 AM
<-- it's like that
Re: Which wastegate actuator is better for the 7.3?
The Banks works fine, but it's probably the most expensive one out there that fits the stock turbo.
Turbomaster makes one that's cheaper, but works every bit as good as the Banks. The difference is that it's a little tougher to install, but infinitely easier to adjust once it's bolted up.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #3 of 30 (permalink) Old 01-07-2009, 02:10 PM
racehauler's Avatar
I like the turbomaster wastegate actuator from Dieselsite. You only have to fight it once to install it, then adjustment is so much easier than with the stock or Banks type actuators.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #4 of 30 (permalink) Old 01-07-2009, 02:24 PM
Lovin the Tuna
RedSmokey's Avatar
What they said! I LOVE MY TURBOMASTER!!!
2001 F250
2000 F250
RedSmokey is offline
post #5 of 30 (permalink) Old 01-07-2009, 02:54 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Turbomaster for sure!
01 F-250 SC PSD,280k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #6 of 30 (permalink) Old 01-07-2009, 03:12 PM
Just A Squirrel
dstruble's Avatar
turbomaster here too!!
Darrin Struble
2003 F-350XLT Sport SC/SB
7.3L Live tuned by Jody ,ITP reg return/intank prepump mods, MBRP S.S. 4" ,afe stage1,foil delete,WW, Dieselsite coolant/trans filters,turbomaster wastegate controller,FTVB,Bandwagon Badges
1956 f100 Heidts Suspension all around
dstruble is offline
post #7 of 30 (permalink) Old 01-08-2009, 01:03 PM
I found the turbomaster to be one of the best mods that I have added.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #8 of 30 (permalink) Old 01-08-2009, 01:58 PM
Proud PSN Sponsor
Deputydog's Avatar
TurboMaster worked well for me!
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #9 of 30 (permalink) Old 01-10-2009, 04:45 AM
Strokin Down Under
OzPowerstroker's Avatar
Yep, notch up another one for the TM from me also
2006 7.3L F250 CC SB 4x4 (RHD made in Brazil) Afe Stg II PG7, TN BB, ITP RR, Banks IC, 4" Ex, DP F6, Fluidampr, BTC, Transgo Tugger, Mag Hytec Pans. 305/70R18 MT ATZs, 4" Icon, OUO Blocks, Bilstein 5100s and FS Ride Rite bags PMR's
OzPowerstroker is offline
post #10 of 30 (permalink) Old 01-10-2009, 05:32 AM
Canadian Stroker
doubledoor's Avatar
Am I missing something here I am running a stock WG and I have no problem hitting 27+psi of boost. Then my SES light comes on. I dont have a boost fooler.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
Human Verification
