can you turn a 7.3 up without new injectors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 12-24-2008, 11:09 PM Thread Starter
I was just wondering if I could turn my 7.3 up like the old 12 valve cummins?
ironmule is offline
post #2 of 10 (permalink) Old 12-24-2008, 11:19 PM
<-Tis the YZ SeasonWOOHOO
Calico5's Avatar
Re: can you turn a 7.3 up without new injectors?
Yes you can. But since your 7.3 is computer controlled, you have to "turn it up" through the engine's computer or PCM ("Powertrain Control Module").
That's where a "chip" comes in. The chip modifies the fueling to the injectors...and "turns it up"!
Click HERE! for a look at DP-Tuner's stuff.
Good luck
Al in SoCal
2000 F350 C-C SRW 4x4 6-Spd
The Usual Stuff: AFE Intake, 38R Turbo, Big IC, Stealth Big oil, Stock AD Smokesticks, DP F5 Chip & PCM: "Live Tuned", Custom Fuel System, Non-EBPV Pedistal , 'T444' CCV, 4" S/S exhaust, Dual "Aussie" Stacks, SB Double-disc clutch
Calico5 is offline
post #3 of 10 (permalink) Old 12-24-2008, 11:20 PM
<----Colin Banks
mattymx's Avatar
Nope... First you will need a chip to control the PCM. 12v's are mechaincal that allows you to turn them up. With a PSD, you need a chip first.
mattymx is offline
post #4 of 10 (permalink) Old 12-24-2008, 11:33 PM
aklim's Avatar
I believe that Banks has an answer.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #5 of 10 (permalink) Old 12-25-2008, 12:01 AM
Senior Member
Larry_Dubya's Avatar
There are other ways too like 10 K , 22 k mod , up the IDM voltage to 140 etc.
Chip is the best way but costs more. Make sure you get a pyrometer first or be dad gum careful with your foot!
'97 F-350 4-WD
E4OD 3.55 gears
7.3 I-C stage 1's
38R
Termy modded 17*
Tru-Cool 4739
Swamps IDM Mod
Larry_Dubya is offline
post #6 of 10 (permalink) Old 12-25-2008, 12:23 AM Thread Starter
I have 4" exhaust from banks with intake and the banks 4 chip from bullydog
ironmule is offline
post #7 of 10 (permalink) Old 12-25-2008, 12:24 AM
Senior Member
how you like that bully dog chip mule?
'97 F-350 4-WD
E4OD 3.55 gears
7.3 I-C stage 1's
38R
Termy modded 17*
Tru-Cool 4739
Swamps IDM Mod
post #8 of 10 (permalink) Old 12-25-2008, 12:25 AM Thread Starter
what is an pyrometer and what 10k and 22k mods?
ironmule is offline
post #9 of 10 (permalink) Old 12-25-2008, 12:28 AM Thread Starter
well to be honest I dont really care for it that much because the turbo lag seemed to get worse if you if you let the rpms get around 1600 and it made my truck shift really hard no matter how I drove and its a 6 speed!
ironmule is offline
post #10 of 10 (permalink) Old 12-25-2008, 01:07 AM
Super Hauler!
Super_Hauler's Avatar
a pyro tells you your exhaust temps make sure you put it in your exhaust manifold and not after the turbo the other mods he talking about can be seen on maintains "how to pages" but i wouldnt do that. I have heard horror stories about that crap.
Super_Hauler is offline
Human Verification
