power increase from gtp38r - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 01-31-2012, 07:29 AM Thread Starter
Boogeyman's Avatar
Been reading about the gtp38r and some places are saying a 80 gain with a chip and exhaust from just a turbo upgrade i find that kinda hard to believe i can understand 25hp or so is there any truth to what they say ?
im planning on picking up a stage 3 snow system in the next few days and maybe a 38r before i do my injectors
02 ecsb afe stg2, wicked wheel, afe bladerunner intake, 4in turbo back mbrp, bully dog shift improver, DI fpr, innovative tunes, stock injectors and turbo (for now)
smoked cab lights, led tails smoked 3rd brake, smoked halo fogs, smoke headlights w led turns 285/75/16 goodyear mt-r`s
heavy metal performance rockdale ill 815-725-8044
Boogeyman is offline
post #2 of 25 (permalink) Old 01-31-2012, 12:26 PM
<-- it's like that
Re: power increase from gtp38r
Who is "they"? I've really never heard anyone say that there would be an 80hp gain from just a turbo swap on an otherwise mostly stock truck.
And no, you won't see much, if any, of a power increase. You'll get lower EGT's, possibly a teeny bit of boost, but that's about it.
By the way, I did directly compare the power output from a stock turbo vs. a 38R with stock injectors and a chip. Prior to the turbo swap, I ran my truck at Bandimere, making many many passes down the 1/4 mile. After the turbo swap, I went back to Bandimere, making many many more passes.
The result: There was zero difference in times and trap speeds.
However, EGT's were about 100 degrees cooler with the 38R.
So..... there you have it.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #3 of 25 (permalink) Old 01-31-2012, 01:36 PM
OSCS's Avatar
Great info
542RWHP "E99" True 5" exhuast system/910's/arp head studs/t-500/RR with fuel system/SB pushrods/gated S366 turbo/250-100/HPX/cutom intake/ DI 6 point/ gear head tunes/BTS
OSCS is offline
post #4 of 25 (permalink) Old 01-31-2012, 01:45 PM
Village Idiot
southmike's Avatar
Largest claim I have seen was 16 hp.
Which you will have a hard time feeling.
Now spool, surge, temp diff you can see.
Now if you had large injectors, and did a turbo swap, maybe.
But basic mods only no great diff.
southmike is offline
post #5 of 25 (permalink) Old 01-31-2012, 02:30 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I went from 320hp to 351 hp on the dyno. But that was different dyno's, thousands of miles apart.
01 F-250 SC PSD,280k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #6 of 25 (permalink) Old 01-31-2012, 03:16 PM Thread Starter
Boogeyman's Avatar
ok thats great to know if i can gain some better spooling charictaristics and better street manners and if i only get minimal gains im a happy camper i would imagine that a 38r swap and water/meth injection would make my truck run very well untill i get the injectors
post #7 of 25 (permalink) Old 01-31-2012, 03:25 PM
Caption This
444-4D's Avatar
What, exactly, are you reading? If you add a chip, exhaust, and a 38r turbo, to a stock truck, you can gain 80 HP.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #8 of 25 (permalink) Old 01-31-2012, 05:24 PM
cota's Avatar
I dynoed a 30 hp increase with no other changes when I went from a stock turbo to the 38r.
Truck had intake, exhaust, and six position chip.
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #9 of 25 (permalink) Old 01-31-2012, 06:22 PM Thread Starter
Boogeyman's Avatar
searching gtp38r on ebay they say 80 gains with a chip and exhaust
i already have tunes and i know i have more than 80hp over stock already. i was just wondering what over what it is now would/should i gain from just the swap
im just looking at it from a egt/boost response standpoint mostly since i plan on doing some pulling with it and street fooling around if i happen to gain 20 -30 hp great
post #10 of 25 (permalink) Old 01-31-2012, 09:54 PM
Old Yeller, REBORN
kilapapipa's Avatar
The spool up is right now vs. the stock turbo.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
Human Verification
