7.3 loss of power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-22-2011, 08:38 AM Thread Starter
7.3 loss of power
I know I should check into some stuff before i post but thought you guys could throw me a few ideas. I used to work out of town so drove my truck only a few times a month and evEry now and again my fiance would drive it well I came home and could feel a big power loss. Changed fuel filter, blew out air cleaner and still low on power and not that I care but it smokes less if that helps you out. I have stage 1 injectors exhaust intake and still have the quick spool turbo! I pull normal boost about 25 wot but it just doesn't go like it used to I raced my buddy tonight in his 04 stock 6l and had a hard time staying with him I'm thinking fuel or oil (hpop)????? Any help would be great thanks
dlonnee is offline
post #2 of 6 (permalink) Old 12-24-2011, 05:21 PM
Paul
HD Rider's Avatar
Re: 7.3 loss of power
In any diesel that sits a lot, algea can grow in the fuel tank and clog the screens in the tank. Have you done the intank mods?
HD Rider is offline
post #3 of 6 (permalink) Old 12-24-2011, 06:34 PM
Get a good scanner on it first to see what codes if any, find out what Hpo psi is at while driving and the duty cycle. Secondly who's injectors and who's tuning do you have?
Having a signature on here does help.
02 f250
countryboyrob is offline
post #4 of 6 (permalink) Old 12-25-2011, 12:07 AM
Freddie
FreddieZ's Avatar
Mine did the same thing, even with the less black smoke almost none at all. Had a buddy of my put it on his scanner and found 2 bad injectors. Don't know how old your injectors are, just a suggestion.
4" exhaust
5" lift
6 position chip
K&N high flow air intake
If it ain't broke don't fix it, just stroke it.
FreddieZ is offline
post #5 of 6 (permalink) Old 12-31-2011, 07:30 PM Thread Starter
they are rosewood injectors and there only about 6 months old
dlonnee is offline
post #6 of 6 (permalink) Old 12-31-2011, 07:37 PM
Custom Trailer Sales
TrailerHauler's Avatar
Check your fuel pressure if the truck sat a lot and didn't get fresh fuel very often.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
Human Verification
