7.3 Slow Crank Problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-24-2011, 10:02 PM Thread Starter
driller338's Avatar
Ive got a 2000 7.3 4x4 with some slow crank problems. This past winter was a cold one here in Illinois and on some cold mornings, my truck would barely start. And when I say barely, I mean barely. Took it and had the batteries tested, and they were shot. So I installed 2 new batteries....that made a huge difference; it cranked fast and with enough oomph to get her started.
About a month later, it was still cranking the same, but it took a little longer to fire. Even when i had it in my 50* garage, it cranked longer than normal before it started. So i thought what the heck, and ran up to NAPA and got a new GPR and threw it in. It started a lot easier with a new GPR, and i thought problem solved...
Well now, 2 months after i installed new batteries, the thing cranks slower than ever when cold. I cycle my GPs 3 times and then turn the key and it cranks about 10 times, slower and slower until it almost stops cranking all together. I turn the key off, cycle the GPs once more, and try it again. The 2nd time it cranks a little faster, but still no start. The 3rd sequence it fires right up and runs perfect. After having ran it, later on in the day, it spins fairly good and fires up like normal....as long as it still has a little bit of heat left i guess.
What are your thoughts? I was thinking maybe the starter? I havent tested the batteries yet, since theyre only 2 months old....but maybe i should (the lights dim and my volt gauge goes down when im cranking). I dont really know where to turn to next without pumping a ton of money into taking it to the stealership. Your thoughts are appreciated!!
driller338 is offline
post #2 of 11 (permalink) Old 03-24-2011, 10:09 PM
SouthFlstrokin''s Avatar
Re: 7.3 Slow Crank Problems
I'm having the same exact issue, does anyone have any ideas?
Early 99 7.3 2wd
Old truck with all the bells and whistles....
Originally Posted by Thuglike View Post
Anyone who stands to pee drives a 7.3.
SouthFlstrokin' is offline
post #3 of 11 (permalink) Old 03-24-2011, 10:11 PM
Hoss1997's Avatar
how old are the glow plugs themselves
1997 F-250HD 7.3 California Edition, ECLB 4x4, Tony Wildman 6Pos Chip
Hoss1997 is offline
post #4 of 11 (permalink) Old 03-24-2011, 10:15 PM
A weak starter can drain the batteries. Hpe old is the starter? How old are the GPs?
02 f250
countryboyrob is offline
post #5 of 11 (permalink) Old 03-24-2011, 10:15 PM
Young'n
powerstrokeracing's Avatar
I would say starter from the way you explained it. Just had this se thing happen to me and thought it was my new batteries but it turned out to bey starter. Good luck.
powerstrokeracing is offline
post #6 of 11 (permalink) Old 03-24-2011, 10:21 PM Thread Starter
driller338's Avatar
Thanks for the feedback. Im the 3rd owner of the truck..and it has 165,000 mi on it....im not sure if the glow plugs or starter have ever been replaced. When it fires on the 3rd try, it runs great with just a little puff of white smoke when it first fires. So that kinda leads me away from it being a GP problem, but you never know.
post #7 of 11 (permalink) Old 03-25-2011, 02:37 AM
Anyone else?
Early 99 7.3 2wd
post #8 of 11 (permalink) Old 03-25-2011, 02:43 AM
Keep er shinny side up!
I had similar issues a few years ago, slow cranking and the truck was eating starters like candy. Turned out to be a bad power feed to the starter, replaced that and no more slow cranking issues. Just one more thing to check out. To clarify the power feed I'm talking about is the one from the pass battery down to the starter.
abbottfarms is offline
post #9 of 11 (permalink) Old 03-25-2011, 02:52 AM Thread Starter
driller338's Avatar
ok, new question. im very interested in getting a gear reduction starter to put in it. what is the best brand and where can you get them at?
2000 Ford F-250 7.3 PSD 6-speed manual. K&N intake. straight pipe. DP-Tuner- 80HP econo & 140 aggressive.
post #10 of 11 (permalink) Old 03-28-2011, 01:29 AM Thread Starter
driller338's Avatar
well got it figured out this weekend. figured i would put a new starter in it...so i jumped in my truck to run to oreillys and she wouldnt even crank! haha hows that for luck? luckily its a manual and i got it rolling down a hill and let off the clutch and got it to start.
put an oreilly gear reduction starter in it, and while tightening the solenoid wire down, it broke the plastic end cap off the solenoid. so, had to run back to oreillys and exchange the starter. put the new one in, and she spun and fired right up like a champ! shut it off, and came back in the morning to leave and it wouldnt start! i could hear the starter spinning, but it wouldnt engage the flywheel. so i had to take it out again, and went and tested it at oriellys. the dumb thing failed both tests. anyways, they exchanged it for a mitsubishi style starter and havent had any problems since. it spins and fires up like a dream.
i just hate chasing my tail around like that...
Human Verification
