2002 7.3 just died - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 03-24-2011, 09:50 PM Thread Starter
tgf
throttle jockey
tgf's Avatar
2002 7.3 just died
Went to pick up a load of feed made it back to the intersection and my truck just shut off. It will crank but it wont start. I am getting fuel, filter has about 5k, oil has 2k on it. Anyone have an as in southwest Missouri/know where I can start looking?
2002 F-350 psd 6-speed, deweze bail bed, 6637, muffler delete.
175/146 injectors, 38r, tuned by Swamps
tgf is offline
post #2 of 33 (permalink) Old 03-24-2011, 09:52 PM
Keep er shinny side up!
Re: 2002 7.3 just died
Does the tach move when your cranking it? If not could very well be the CPS....
abbottfarms is offline
post #3 of 33 (permalink) Old 03-24-2011, 09:56 PM Thread Starter
tgf
throttle jockey
tgf's Avatar
That's what I was thinking, no tach movement. Is it common for them to just up and quit?
tgf is offline
post #4 of 33 (permalink) Old 03-24-2011, 10:00 PM
yup sure is, I carry a spare in my glove box...
post #5 of 33 (permalink) Old 03-24-2011, 10:05 PM Thread Starter
tgf
throttle jockey
tgf's Avatar
My search button doesn't work, is it the light grey from international the good one or is my memory failing
tgf is offline
post #6 of 33 (permalink) Old 03-24-2011, 10:18 PM
Ouch's Avatar
Send a message via Yahoo to Ouch
Blacks the good one.
Ouch is offline
post #7 of 33 (permalink) Old 03-24-2011, 11:15 PM Thread Starter
tgf
throttle jockey
tgf's Avatar
Pulled p1670 p1211 p0542 codes with an sct scanner
tgf is offline
post #8 of 33 (permalink) Old 03-24-2011, 11:26 PM
Rock Steady
I got two (also in the glove gox) a black and a grey. Whichever gets you goig is the good one ,right.
2000 F-450 Dump NLTD tunes
4duggan is offline
post #9 of 33 (permalink) Old 03-25-2011, 01:00 AM Thread Starter
tgf
throttle jockey
tgf's Avatar
I replaced the cps, still no start. We did pull the follow codes
p1670 p1211 p0542 with an sct scanner.
tgf is offline
post #10 of 33 (permalink) Old 03-25-2011, 02:41 AM
Does the tach move now while your cranking? WTS light cycle on and off as usually? Dumb question, but have you checked your oil?
Human Verification
