weird miss and a whole lotta fuel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-15-2011, 01:10 AM Thread Starter
Well this is my first post....but i have an 02 f-350 auto 2wd that has a weird problem. when you start the truck it has a miss and smokes quite a bit. i changed the fuel filter(twice), cps, air filter, and batteries(old ones were dead). right after i changed the fuel filter the truck ran like a champ and then went back to missing...both times i changed the fuel filter. so i hooked up the scanner and these are the codes that i pulled. p0541, p0603, p1118, p1211, p1670.....wtf? i just bought the truck from an auction so i dont know much of the history other then i got it cheap and now i think i know why. also i noticed that when i had to key on booting up the scanner there was some smoke from under the hood--the intake heater was running for a while while the key was on and never shut off--the boot was smoking. it would let me do the buzz test and they all worked. the contribution test it just kept telling me the intake air heater a circuit low and would not perfrom the test. im new to the 7.3 but def. not diesels........just need to know what and where else to look next. any help is appreciated, as i need this truck up and running to use as our service truck and my daily driver to get home and back to the shop
pmpislander is offline
post #2 of 8 (permalink) Old 02-15-2011, 01:51 AM
Custom Trailer Sales
TrailerHauler's Avatar
Re: weird miss and a whole lotta fuel
PO541 Manifold Intake Air Heater
p0603 Keep alive memory error
P1118 Manifold Air Temperature Sensor Low Input
P1211 Injection pressure out of range, above or below desired
P1670 EF Feedback Signal Not Detected
Do you know what your ICP is?
And how many miles are on the truck?
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #3 of 8 (permalink) Old 02-15-2011, 02:21 AM Thread Starter
truck has 212,000 on the odometer, and i wanna say that the trucks fuel pressure was around 460psi at idle....if that is what you are asking about the icp--if not then i dont know
post #4 of 8 (permalink) Old 02-16-2011, 03:21 AM
jc82chevyman's Avatar
Thats tough to diagnose with out a cylinder contribution test and measuring your ICP and the IPR duty cycle to ensure the injectors are gettin enough oil to operate properly and you could be having a weak fuel pump issue which would explain why it ran great with a new less restriction or a weak HPOP
jc82chevyman is offline
post #5 of 8 (permalink) Old 02-17-2011, 06:59 PM Thread Starter
well i can tell you its def getting to much fuel--i would think that the fuel pump or hpop are not the problem as i have white smoke out the a$$! its enough to smog out the shop that im workin in, and you can smell the raw fuel.
post #6 of 8 (permalink) Old 02-18-2011, 12:10 AM
Demon Dually
speeddemon31176's Avatar
Injector stuck open?
speeddemon31176 is offline
post #7 of 8 (permalink) Old 02-18-2011, 12:43 AM
Freak'n know it all
gottagofast's Avatar
whatever it turns out to be DO NOT DRIVE it while it's white smoking..... it'll cost you an engine...... trust me on this one
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #8 of 8 (permalink) Old 02-19-2011, 04:14 PM
First off I would check your fuel pressure up around the bowl somewhere, because of the comment you made about it running fine with a brand new fuel filter.
Then I'd find out what your ICP/ duty cycle is and run a contribution test.
If those are the original injectors you could be due for a set.-
Human Verification
