Time to replace injectors & HPOP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 01-07-2011, 02:23 AM Thread Starter
rancher76's Avatar
I have failed #2 cylinder injector twice now, so I guess it is time to bite the bullet and replace my injectors. Will go with either beans or swamps, have not made my mind up yet. I read swamps R&R and it seems fairly sraight-forward. I took the truck for a test drive tonight with my AE and got some disturbing readings with my HPOP. I monitored ICP and ICPDC. At 1900rpm, I was flucuating between 1200-2000 psi and my D/C was 24 to 28% with one dip to 10%. I am guessing my pump is worn out, am I guessing right? If it needs replaced, I have been reading on the stealth and like what I have heard about it. I am just going back stock, am I going down the right path? thanks for the help!
early 99 F250 ex cab long bed 6 spd 239k+miles bone stock!
2012 F350 SRW ex cab long bed 95K miles stock
rancher76 is offline
post #2 of 16 (permalink) Old 01-07-2011, 03:20 AM
TBarrsTruck's Avatar
Re: Time to replace injectors & HPOP
Surprised that you need injectors with that low of miles, but possible. You might just replace #2 and call er good. Readings don't look that bad on the pump. If your getting bigger than a stage one injector, or ever plan on it, then look at an upgraded pump, otherwise no need.
'97 4x4 ECLB: SD IC, TW 4 pos, afe, 3-4" w/areoturbine, 4 gauge, DIY stage 1s, GTP38R, cust E-fuel, E-brake, stage3 CM meth, 439hp still trying for 600. cust stereo, highamp alt, cust paint
'78 F-150 RCLB: 460 swap, 3" lift, 33's,Trussed 9" w/ chrome-moly shafts, cust stereo, locked front/rear. My first love! EFI & Turbo coming soon...
TBarrsTruck is offline
post #3 of 16 (permalink) Old 01-07-2011, 03:30 AM
Freak'n know it all
gottagofast's Avatar
yep those aren't any biggy..... get it warm and run it wot uphill riding the brakes for a better idea of the pump's condition
Also a cylinder contribution test does NOT diagnose a bad injector without further testing.... could be one of several possible problems
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #4 of 16 (permalink) Old 01-07-2011, 11:05 AM Thread Starter
rancher76's Avatar
I am still learning a LOT about AE, what other tests do I need to run? Thanks for the responses, sounds like it not as bad as I thought it was. The symptoms that made me test it in the first place is the truck is smoking on start up, I had a thread on this about 1 month ago, MPG's have decreased from 15.5/16 to 12.5/13, and truck seems "goosey". It gets to bucking and in lower gears will have a surging feel/sound to it. At speed, I can hear it surge occasionaly, but I noticed yesterday that if I set the cruise, it does not do it. Sorry to ramble on , I just want to try to fix this!
post #5 of 16 (permalink) Old 01-07-2011, 11:26 AM
Headwind Magnet
JerseyJim's Avatar
Couple of thoughts:
Normal lifespan on the injectors is about 200k if they are fed a diet of clean fuel and oil. Are you the original owner? If not, 150k is plausible for the injectors to be worn out.
I assume you ran a CCT and determined #2 needs replacing. You should also run a buzz test on a cold motor and see what it shows. Sinister Diesel as some good advice on the buzz and CCT tests on their website.
Drives better on cruise control - If true, that would indicaet a bad TPS. I think you can check it with AE. Do this before you throw and parts at it.
Lastly, if its not the TPS, call Swamps and talk to Dave or Jonathan. Get their opinion on what to do - stand up guys who won't steer you wrong. BTW, I had them overhaul my injectors and IDM and am VERY happy!
Good luck!
Best,
Jim
2002 F-350 SC/SB/SRW 4X4 auto- Tymar intake, AIH delete, Swamps injectors, Swamps IDM, Dieselsite Coolant Filter,
Bilsteins with a stock ride height.
JerseyJim is offline
post #6 of 16 (permalink) Old 01-07-2011, 10:19 PM Thread Starter
rancher76's Avatar
Originally Posted by JerseyJim View Post
Couple of thoughts:
Good luck!
Best,
Jim
I bought my truck 6 years ago, it had 80K on it. I used rotella and changed it every 4K, fuel filter every 8K. Just changed to Mobil1 5W40 @160K, got about 2K on this oil change now.
I was going to do a buzz test in the morning and see how it did. I filled up today, 25.8 gallons on 264 miles !
I have been looking through the AE tests in the library, I am going to check the TPS also.
Thanks for the responses, still open for any other suggestions.
On edit: I was also going to take the boots off and clean everything, just in case I have some boost leaks. I have been meaning to do this for a while anyways, just another thought I had.
post #7 of 16 (permalink) Old 01-08-2011, 04:10 PM
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
like stated above, a cylinder failing a CCT does not mean a bad injector, it means the operation of that cylinder is not up to par. Which could be caused by worn rings, cracked piston, burt/bent valve(s), or a malfuntioning injector.
Now a malfunctioning injector could be caused by a few things: IDM problem, wiring problem between IDM and injector(under cover harness, valve cover gasket, enternal conector call all melt and fail) or a bad injector itself
run the buzz test and if all is good there, it rules out the electrical portion.
after that you need to to a compression test. If that is all good, then and only then can you be sure you need to replace the injector
CCLB with some stuff done .....
BigRed97 is offline
post #8 of 16 (permalink) Old 01-08-2011, 04:16 PM
Busted Knuckles
PSDEng's Avatar
Try a rotational velocity test.
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #9 of 16 (permalink) Old 01-08-2011, 04:38 PM
Freak'n know it all
AFTER all the other tests and before ordering a new injector you can also swap the offending injector with another cylinder to see if the problem follows it.
autometer gauges,
post #10 of 16 (permalink) Old 01-08-2011, 04:52 PM Thread Starter
rancher76's Avatar
Ran the buzz test this morning, truck had been sitting about 14 hours, buzz test sounded good, don't know if it means anything or not but I watched the tach while it was doing the test and it peaked at the same RPM everytime. Then I did the accelelator test and all readings were within what specs the sheet gave. Then I started the truck and did the Vehicle & HPOP Health Check form the library. My volume of fuel desired and fuel injector pulse width was a lot lower than what the form showed. The form showed 14.5 mm3@ idle (mine was 7.3) and 24.8mm3 @ WOT (mine was 14.4) for volume of fuel desired. The pulse width showed 2.96ms @idle (mine was 1.85) and 1.80ms @ WOT (mine was 1.47). Then I checked the rotational velocity, all were 0.00.
Again, a big THANKS for all the help. I am starting to get a little frustrated with the old truck, but I'm hanging in there.
Human Verification
