7.3 dies when warm. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 01-02-2011, 09:24 PM Thread Starter
7.3 dies when warm.
I been reading up on my symptons for the last few days and learned alot but I still cant figure it out so im hoping somone can help.
99 powerstroke no mods not mine
first start it up it will run for 10 to 15 min and get a skip every few seconds and eventually stall.
wait a few seconds and fires right up but will stall again. seems to get worse till it wont start untill it cools off.
if i idle it up it will stay running but skips evey few seconds then worse.
After it warms up at idle the injector pressure runs around 550 psi and 1000 psi at 2 grand.
After it stalls i check the hpop res and its full to the top.
fuel filter is full with pressure.
I clear the codes then run it untill stall no coades come up.
Hasnt been a year sence the HPOP was replaced and the first thing i replaced was the cps
I have read that the o rings could be bad on the Ipr and for oil in the plugin yes i think there is some.
When the IPR gets bad will it show the presser drop off? It doesnt seem to go below 550 psi before it stalls but when it picks up after the skip the preasure reads around the 800 psi range.
Im stumped and from what i read from this site im not sure if im heading the right direction.
Thanks in advance
99.5 350 srw stock 3.73 gears l/s rear custom flatbed sander plow pure work truck
7.3PowerStroke is offline
post #2 of 11 (permalink) Old 01-02-2011, 09:26 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: 7.3 dies when warm.
Injector more then likely... Watch this video...
This would only happen after the oil got above about 110*...
About the most frustrating thing I have ever dealt with working on these trucks.
01 F-250 SC PSD,280k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #3 of 11 (permalink) Old 01-02-2011, 09:44 PM Thread Starter
Yeah that crossed my mind. from what i understand it robs from the rest and thats what my skip could be. and from what im told the oil hasnt been changed in a while too.
Thanks for the advice.
post #4 of 11 (permalink) Old 01-03-2011, 08:48 AM
Freak'n know it all
gottagofast's Avatar
Lift pump?
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #5 of 11 (permalink) Old 01-03-2011, 02:58 PM
CSIPSD's Avatar
Originally Posted by gottagofast View Post
Lift pump?
There is no "lift pump" on a 7.3... Just a fuel pump.
But a fuel pump would not effect HPO pressures...
Joe
CSIPSD is offline
post #6 of 11 (permalink) Old 01-03-2011, 04:17 PM
Freak'n know it all
well we don't have an injection pump but our fuel pump carries fuel from the tank to the injectors which do the job of an injection pump..... we could argue as to whether it could be called a lift pump or not but honestly it doesn't matter that much..... I would agree that we don't have to call it a lift pump since it's the only pump we have.
either way.... I didn't see anything in his post that indicated that there was a hpo issue.... apr 500 at idle is normal. "1000 psi at 2 grand" doesn't mean alot without load, duty cycle, and throttle percentage.
"550 psi before it stalls" normal if at idle..... "when it picks up after the skip the pressure reads around the 800 psi range" again, doesn't mean anything without the conditions under which it occurred.
I suggested the fuel pump based on the symptoms of stalling after running for a couple minutes. Electric pumps tend to die in just that manner..... It could well be a HPO issue but I don't see where it has been proven as such.
autometer gauges,
post #7 of 11 (permalink) Old 01-04-2011, 12:51 AM
Headwind Magnet
JerseyJim's Avatar
Have you tried a buzz test on it when its cold?
Best,
Jim
2002 F-350 SC/SB/SRW 4X4 auto- Tymar intake, AIH delete, Swamps injectors, Swamps IDM, Dieselsite Coolant Filter,
Bilsteins with a stock ride height.
JerseyJim is offline
post #8 of 11 (permalink) Old 01-04-2011, 02:31 AM
Custom Trailer Sales
TrailerHauler's Avatar
Best,
Jim
Buzz test only checks for an electrical connection to the injectors. Contribution test tells you whether or not all 8 injectors are firing.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #9 of 11 (permalink) Old 01-04-2011, 03:10 AM
Headwind Magnet
JerseyJim's Avatar
Yes but it also checks the injector solenoids. A problem that shows itself only when warm could be a problem with a solenoid. Heat changes resistance, clearances, etc. I would run a buzz test on a cold motor, warm it up and wait for it to die and run it again. I could be way off base on this but its an easy test to do without pulling the vc's.
BTW, a bad solenoid on one injector can kill a whole bank or even the IDM if it's bad enough. Got some experience with this
Best,
Jim
post #10 of 11 (permalink) Old 01-04-2011, 07:49 PM
Yes, part of the electrical connection to the injector. I guess I could've been a little less vauge.
I know where your going with the buzz test now, a wire that comes apart just enough when it warms up, to kill the connection. And you could check for it with a buzz test like you said, I didn't understand you at first.
I hate wiring problems!
Human Verification
