I know plenty of guys out there complaining of poor power steering, especially while trying to turn lock to lock while not moving. The pumps and gearboxes on the SDs are not the greatest, but I found this procedure for bleeding the SD power steering system on AllData. I have used it several times over the last year while replacing some PS parts. Read on.
For me, this worked excellently. I can quickly turn lock to lock while standing still.
- Lift and suspend the front end off the ground to clear the tires.
- Open the PS reservoir and make sure the fluid is topped off. I used Mercon V as recommended.
- This part is not in the procedure, but trust me, you'll want to use it. Double up some strong rubber gloves; they work best. Take the doubled-up rubber gloves to close off the PS reservoir using the opening where you would stick your hand. You want this rubber glove "lid" to keep the PS fluid inside the PS reservoir as your burping the air out. Clip a small tip off one finger to allow air to escape. The alternative is to keep refilling the reservoir as you burp fluid and stand out. Without the gloves, you will have PS fluid all over the frame and gearbox.
- Now, this is where you will be burping the air out of the system.
- Inside the cab with KOEO, begin to turn the steering wheel lock to lock slowly. It will be tricky, but you're forcing fluid through on the right turn and air out on the left, or vice versa, IIRC. When the air is being forced out, it is also causing the fluid in the reservoir to splash, hence the gloves.
- You will usually need to go lock to lock at least 20 - 25 times to get all air out. If you replaced any parts, such as the pump, gearbox, lines etc., you might need as many as 60 turns to lock.
- You may need to check fluid periodically as you're bleeding air out and pushing fluid.
