Symptoms of a bad IPR? - Page 3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #21 of 23 (permalink) Old 03-29-2008, 06:46 PM Thread Starter
HP Junky
Re: Symptoms of a bad IPR?
Originally Posted by kainers View Post
Also even though you have idm codes that doesn't mean IDM problem.Your armiture plate may be hitting the syliniod.Basically your clearances are out on an injector.
I agree, thats tomorrows project. Gonna check the clearence on my #8 injector...
RockinJW is offline
post #22 of 23 (permalink) Old 03-30-2008, 11:47 PM
SmokeWithEveryStroke's Avatar
Maybe I am having the same problem. While I am sitting at idel my truck starts to idle down like its going to stall then idles back up then levels out sits at normal then down again then back up then to normal.
When it drops it usally below 500 then idles up to around 800-850 then to normal 650-700
99 ExCab Sb 6spd pulling truck (PULL-N-PRAY)
08 cclb
SmokeWithEveryStroke is offline
post #23 of 23 (permalink) Old 04-06-2008, 11:26 PM Thread Starter
HP Junky
Spent the day working on the truck. Looks like it turned out being a short in the wiring to the engine oil temp sensor. Fixed the wires and all seems to be at peace again
Big thanks to Mr. Wackjob at WOP
RockinJW is offline
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/13-7-3l-power-stroke-technical-info/8285-symptoms-bad-ipr.html
Posted By For Type Date
7.3 Powerstroke IPR Valve Symptoms_Yaelp Search This thread Refback 09-27-2016 10:22 PM
