7.3 fuel leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 11-03-2010, 11:44 PM Thread Starter
7.3 fuel leak
Hi, my boss has a 2002 f350 with a 7.3 in it, the prolbem is it is leaken fuel on top of the motor. Im not for sure what fuel issues they have or what uselly goes bad to cause it to leak. I dont know much about the 7.3, I have mailnly worked on my 6.0. Can someone shine some light on what direction to take so im not ripping the top half of the motor off for no reason. Thanks John
lt.co.11 is offline
post #2 of 13 (permalink) Old 11-04-2010, 12:31 AM
FordCowboy's Avatar
Re: 7.3 fuel leak
Most likely the o-rings for the drain valve on the fuel bowl. Look at the back side of the fuel filter housing with the engine running or key on and look for drips. Other than that it could be any of the other fuel lines going into the fuel filter housing so look at them.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #3 of 13 (permalink) Old 11-04-2010, 12:52 AM
Re: 7.3 fuel leak
Just had to replace the fuel line that runs from the fuel bowl back to the rear of the head on the passenger side. It runs under the turbo and there is a metal clamp there that will rub a hole in the metal line. Good luck
srswain is offline
post #4 of 13 (permalink) Old 11-04-2010, 03:17 AM Thread Starter
Re: 7.3 fuel leak
Ok, thanks at least thats a starting point.
lt.co.11 is offline
post #5 of 13 (permalink) Old 11-04-2010, 03:35 AM
fishyPSD's Avatar
Re: 7.3 fuel leak
Dealing with the same issue on my 01. Looks like my leak was from the fuel bowl cap gasket. I changed the filter and orings yesterday and it looks like it has stopped. I'll be keeping an eye on it though.
fishyPSD is offline
post #6 of 13 (permalink) Old 11-04-2010, 03:37 AM
20007.3stroker's Avatar
Re: 7.3 fuel leak
just had mine rub threw this spring, but it could also be orings. if its losing fuel fast id say line considering when mine wore threw you could almost follow where i went at about 25mph. slow id say orings.
2000 7.3 f-250 4X4 CCSB
Mickey Thompson rims
Cooper Discoverer S/T tires
f350 front springs, add leaf and added overload in rear
Warn manual front hubs
Straight piped
AFE stage 1 kit
more power mods starting as $$ allows
20007.3stroker is offline
post #7 of 13 (permalink) Old 11-04-2010, 01:16 PM
Re: 7.3 fuel leak
Check the 2 lines on the passenger's side of the fuel bowl and 1 line on the driver's side of the fuel bowl. They have sleeves, not o-rings, that form the seal inside the line. Mine had rotted away and that's where my leaks were coming from. I believe they're referred to as Parker Fuel Sleeves.
bill4d is offline
post #8 of 13 (permalink) Old 11-04-2010, 01:40 PM
PSN nerd
Re: 7.3 fuel leak
Thats where mine was leaking
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #9 of 13 (permalink) Old 11-04-2010, 01:54 PM
Village Idiot
southmike's Avatar
Re: 7.3 fuel leak
mine leaked there a few years ago..caught by dealer was a very expensive repair for the 2 orings..
do it yourself cheap.....and easy
southmike is offline
post #10 of 13 (permalink) Old 11-04-2010, 01:56 PM
Re: 7.3 fuel leak
i got a fuel bowl repair kit from guzzle, should be here today. sick of the leaking mess, thought my clutch was heading south, then i smelled fuel...lol
03_PSD is offline
Human Verification
