Front Crank Seal Replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 10-31-2010, 08:56 PM Thread Starter
I have to replace the front crank seal on my '01. I've reviewed some threads here on it, but all are closed and I have some additional questions. I'm reluctant to pull the radiator, one of my tranny lines is marginal. I intend to replace it, but not immediately, I need the truck up asap. I've got the fan and shroud off and have pretty good access to the crank bolt. My impact won't fit in there. I can see three holes in the spokes of the damper, I assume these are threaded to pull the damper. Can anyone tell me what thread they are?
Another problem I'm having is figuring out how to lock the crank to loosen the crank bolt. The truck is an auto, and I'm alone. Any tips?
God, Guns and Guts Made America Free!!
Darryl Worley
Redneck Steve is offline
post #2 of 15 (permalink) Old 11-01-2010, 11:52 PM Thread Starter
Re: Front Crank Seal Replacement
Any help?
Darryl Worley
post #3 of 15 (permalink) Old 11-02-2010, 01:57 AM
PSDfan99's Avatar
I did mine without the special tool and it leaks, thats about all I know. Got to replace it one of these days, and when I do I'll use the right tool.
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #4 of 15 (permalink) Old 11-02-2010, 09:58 AM
Demon Dually
speeddemon31176's Avatar
The crank bolt loosening will require some ingenuity. A good balancer puller will do the job once you get the crank bolt out.
speeddemon31176 is offline
post #5 of 15 (permalink) Old 11-03-2010, 04:58 PM Thread Starter
I've got two questions here folks:
1. What size bolt will fit the holes in the spokes of the damper?
2. Any tip on how to lock the motor in place by myself to deal with the crank bolt?
Thanks
Darryl Worley
post #6 of 15 (permalink) Old 11-04-2010, 01:56 AM
Demon Dually
You could try using a hammer on the breaker bar or wedging the beaker bar against the frame and pull the fuse or disconnect the uvc plugs from the valve cover gaskets and bump the key to break the bolt loose. I can't remember off hand what size the threads are for the holes in the dampener.
post #7 of 15 (permalink) Old 12-20-2010, 10:15 PM Thread Starter
I found out the thread size on the bolt holes for pulling the balancer are 10mm x 1.5. I completed the job using tips I found on the Board here, but I still have a severe leaking problem. When I pulled the balancer, all indications of the front seal being bad were there. The back of the balancer was soaked and it had flung oil all around it. There were no obvious other areas on the front that were oil soaked, and when the truck was running, it appeared the oil was streaming form the seal.
Anyway, it still leaks as bad as before the replacement, a gallon an hour. Once that amount leaks out, it doesn't seem to leak until more oil is added.
I'm wondering now if the crankcase vent might be plugged. I looked around the Board earlier today looking for a thread on servicing the vent but didn't find one. I've seen them referenced but couldn't find a thread. Any suggestions?
Darryl Worley
post #8 of 15 (permalink) Old 12-20-2010, 10:23 PM
To check and see if the vent is pluged take the oil cap off and run it and see if it still dumps the gallon.
2002 Ford F250 quad cab short box/Intake/Exhaust/BTS Trans/Matts Tunes
pilot4life is offline
post #9 of 15 (permalink) Old 12-20-2010, 10:44 PM
Lovin Life...
02BigD's Avatar
Lock tight on the front seal?
RTV around the balancer bolt? Did you give the lock tight and rtv time to set while everything was dry?
Did you take off lpop to see if the front cover was scared?
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
post #10 of 15 (permalink) Old 12-20-2010, 11:16 PM
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
sounds like you did not replace the wear ring on the balancer, that is what the seal rides on. a new seal will not seal on a worn ring(99% of the time)
you have to redo it and replace the wear ring
CCLB with some stuff done .....
BigRed97 is offline
Human Verification
