IPR problems.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 10-21-2010, 12:05 AM Thread Starter
IPR problems....
I have seen many IPR problems, all consistant with taking out the IPR and cleaning it then have more problems or worse afterwards. Has anyone ever really fixed the problems?
I have a '97 powerstroke with intake mod and Superchips tuner. I have replaced the valve cover gaskets and wiring, replaced CPS, and Glow plug relay with the Stancor unit. It has alway had what feels light a slight miss. Under throttle it really shows up worse. It chugs sometimes between 35 and 50 mph.
I thought maybe the IPR was dirty so I took it out to clean it. Probably the worse mistake I could have made. Now it runs like crap, idles from about 650 up to over 900 then back down. Codes are 1209, 1282, 1210, 1211. I see that they all are associated with the IPR. I took it out again, put new O-rings in made sure it was put together like it came apart but stll runs same codes and Idle problems.
Any Ideas, or suggestions? Mike
voodoomaker is offline
post #2 of 12 (permalink) Old 10-21-2010, 12:11 AM
Demon Dually
speeddemon31176's Avatar
Re: IPR problems....
Yep, get a new IPR. You either lost something or it is the electrical part of the IPR that is not working correctly and you can't repair that.
speeddemon31176 is offline
post #3 of 12 (permalink) Old 10-21-2010, 02:20 AM Thread Starter
Who would have it the cheapist? International wants $300
post #4 of 12 (permalink) Old 10-21-2010, 02:57 AM
Mark J.'s Avatar
make sure you didn't bend a pin while reconnecting the wire plug in, double check the tin nut,then
Ebay
Mark J. is offline
post #5 of 12 (permalink) Old 10-21-2010, 03:13 AM
Sponsor
TerminatorEngineering's Avatar
Ebay, then me. Mine are $180.
Visit us at:
for all your Big Oil needs.
SDRCM #7
TerminatorEngineering is offline
post #6 of 12 (permalink) Old 10-21-2010, 07:25 AM
Mark J.'s Avatar
would be your best bet , better quality then ebay!!!
Mark J. is offline
post #7 of 12 (permalink) Old 10-21-2010, 07:38 AM
i got mine on ebay for 140 new
Bockhold is offline
post #8 of 12 (permalink) Old 10-21-2010, 06:20 PM Thread Starter
Thanks for the help guys. I see that Fleet Source has one for $159.00 Free shipping. Anyone else close to that? Mike. I'm in Vancouver, Wa
post #9 of 12 (permalink) Old 10-23-2010, 02:46 AM
Can a 1 ton do a wheelie?
purple_heart_350's Avatar
Are the IPR o-rings metric?
'95 F350
IDM mod, FPR shim, 3 1/2" DP and CAT delete, aFe Big Boost, Quad pod-autometer Z seires gauges, 4" straight pipe exhuast, TS 6 position chip from KT performance
"Would it kill you to buy american" Clint Eastwood
purple_heart_350 is offline
post #10 of 12 (permalink) Old 10-24-2010, 08:31 PM Thread Starter
Well it looks like i'm on my way to getting it fixed. IPR was sticking so I replaced that and ICP was weak also.
I really owe a big THANK YOU, to COTA. He stepped up and loaned me a few parts for repairs and diagnosis so I wasn't chasing my tail and wasting money. Also thanks to the others who helped with suggestions. Great bunch of people! Mike
Human Verification
