Low boost issue.......... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 10-05-2010, 11:21 PM Thread Starter
It's done this since I got it 2 weeks ago. I changed the oil, filter, fuel filter, and replaced the EPV sensor tube. It doesn't blow any smoke like the fuel is there, but the air isn't. There's no smoke at all. I installed my boost gauge out of my Ford Probe and the truck will show 1-3 pounds at WOT until about 2,500rpms, then runs up to 10 pounds until it shifts around 3,200rpms. Also, once it starts making boost around 2,500-2,700rpms, there's a God awful squeal kind of like a tea kettle, almost like something is in the way of the airflow. It;s either not making enough boost due to a restriction and the MAP sensor is telling it to cut fuel or it's not producing enough fuel to make the heat it needs to make boost due to an injector or something being bad. Maybe the EBPV flapper/butterfly???
1986 Ford F-250, 6.9l, 4 speed, 4x4, regular cab, long bed
Firearms stand next in importance to the Constitution itself. They are the American people's liberty teeth and keystone under independence. -- George Washington
junkman306 is offline
post #2 of 31 (permalink) Old 10-05-2010, 11:31 PM Thread Starter
Re: Low boost issue..........
It also shakes pretty good at 1,500rpms or lower when in overdrive.
post #3 of 31 (permalink) Old 10-05-2010, 11:32 PM
Super Hauler!
Super_Hauler's Avatar
are you getting any low boost codes? How much play is in the turbo wheel left to right and up and down? Sounds to me like your wheel is coming in contact with the housing and causing the noise you mentioned
Super_Hauler is offline
post #4 of 31 (permalink) Old 10-05-2010, 11:36 PM Thread Starter
It throws a p1247 and you may be right. I haven't checked the wheel yet, but it does sound like putting a paper clip into a fan, but at a lot higher speed, so it could be hitting. I'm going to check it tonight/tomorrow to see if the intake side is worn from "dusting" or if it's making contact.
post #5 of 31 (permalink) Old 10-05-2010, 11:44 PM
2006nytro's Avatar
id bet the turbo is it bearing or something
2000 ford 7.3 more than some less than others..
RIP will Iott
we will miss you..
[Cat_Rebel] 11:50 pm: That would be fun to go to & meet pornstars...........oh....hi..I'm your biggest fan...well atlest I spank it to you
everynight
2006nytro is offline
post #6 of 31 (permalink) Old 10-05-2010, 11:45 PM Thread Starter
And I checked my average after my first tank of fuel and it was 15.1mpg. I only drive it to work at the moment so thats 25 miles highway 1 way, 4 days a week. I should be getting alot better mileage than that.
post #7 of 31 (permalink) Old 10-05-2010, 11:53 PM
Starting Over
kainers's Avatar
You have a leak along with other things maybe but definite boost leak.
kainers is offline
post #8 of 31 (permalink) Old 10-06-2010, 12:02 AM Thread Starter
But wouldn't it blow a little black smoke when floored from a stop due to the computer adding x amount of fuel assuming x amount of boost will be there if it was a boost issue and not a fuel issue?
post #9 of 31 (permalink) Old 10-06-2010, 03:28 AM
<--501cc,should b 540 : /
'99 stroker's Avatar
Im pretty sure the computer fuels as it sees boost, not predicting by it.
Early '99 ccsb 7.3l 4x4 6spd
All Stock Except
Air tank rear bumper
Brush guard w/ fog and driving lights
seat covers
after market floor mats
Fancy Halogen headlight bulbs
Rear license plate light is out
Originally Posted by erikclaw View Post
Those hairy bastards are scary up close!
with all the smoke, power and wheelie popping you might accidently park on a honda
'99 stroker is offline
post #10 of 31 (permalink) Old 10-06-2010, 09:04 AM
Starting Over
kainers's Avatar
it 100% describes what your telling us as symptom.Especially the whistle once boost is built.Telling you have a leak.
kainers is offline
Human Verification
