Smelling raw fuel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 09-27-2010, 03:56 PM Thread Starter
shock's Avatar
Smelling raw fuel
I can smell raw fuel at start up is burns your eyes. The truck starts good only turns over 2 maybe 3 times. and just a very little smoke you c an barely see it? Glow plugs? should i try pluging in the truck to see if that goes away?
shock is offline
post #2 of 9 (permalink) Old 09-27-2010, 04:22 PM
Sponsor
SeeYa's Avatar
Re: Smelling raw fuel
First thing to do is scan for codes with a code reader. Do you have one?
My first thought though is to have you check under the valve covers to see if the uvch has come unplugged, loose or wires frayed, etc. This would surely cause what your describing.
Diane
Diane @
828-221-0076 x 802
SeeYa is offline
post #3 of 9 (permalink) Old 09-27-2010, 04:46 PM Thread Starter
shock's Avatar
no i do not have a code scanner. You need a diesel one correct? it kinda goes away after it is warm for the most part.
shock is offline
post #4 of 9 (permalink) Old 09-27-2010, 05:05 PM
Sponsor
SeeYa's Avatar
Yes, it will need to be a scanner that will read diesel codes. My thought was only something to check. It could be anythng. UVCH plug issue, Injector needle and seat not sealing off and dribbling, Glow plugs not cycling properly to name a few. Checking for codes will help with diagnosing.
Diane @
828-221-0076 x 802
SeeYa is offline
post #5 of 9 (permalink) Old 09-27-2010, 09:09 PM
fueled by Colecovision
golfer's Avatar
Garage
If you don't have any check engine/service engine lights on...then it isn't going to be wiring.
The PCM does not monitor cylinder (or injector) "balance"...but it sure as hell monitors electrical continuity (between the PCM, IDM, & injectors).
the white smoke is surely going to be a mechanical problem...
either high mileage injectors (>180k), low engine compression...bad fuel, no fuel pressure...or leaking injector nozzles.
golfer is offline
post #6 of 9 (permalink) Old 09-27-2010, 11:30 PM Thread Starter
shock's Avatar
There is no real white smoke you have to like you would think you have to really really look. No check engine lights. I am lost on this it runs real good no shake or anything it got good fuel ecomony from iowa were i bought it avg 17 to 19 about
shock is offline
post #7 of 9 (permalink) Old 09-27-2010, 11:39 PM
Well Hung Member
stroked's Avatar
seems like these answers are the worst case scenarios, check the back of your fuel bowl, towards the bottom, theres or rings there that are notorious for leaking, and the smell will seem like it goes away, but itll gradually get worse. check the easy stuff first,
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #8 of 9 (permalink) Old 09-28-2010, 02:21 AM
< wish it was mine
Stroken7.3's Avatar
Thats what I was thinking. You should be more specific, is it a raw fuel smell from the front of the truck and in the cab? or were you smelling it from the exhaust?
2001 F-350, Auto, No Limit Tunes, Autometer Ultra-lite gauges.
Stroken7.3 is offline
post #9 of 9 (permalink) Old 09-28-2010, 04:20 AM Thread Starter
shock's Avatar
Very sorry rear of the truck the rear only. i pull the hog in the garage and then in the am i smell raw fuel like a leak no spots on the floor though. or wet spots? fuel bowl drain o rings?
shock is offline
Human Verification
