Signs of injectors going bad? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 09-23-2010, 02:01 AM Thread Starter
Mtack's Avatar
I am sure this has been asked before but I have a question for you guys. The last couple of months I have noticed if I lug my truck down to about 1200 rpms it almost feels like a miss. I just changed the oil, fuel filter, and checked everything out. The reason I wonder about injectors is if I run Dieselkleen, two stroke oil, etc. it seems to almost go away. As a final test I filled up yesterday with no additives and it once again has a slight miss at about 1100-1300 rpms. Runs fine at speed, idles good, but fuel mileage is down about 2 mpg. I just ordered Autoenginuity from Diesel Power Products so I can check it out a little better. Do any of these symptoms seem like injectors? It has 168,000 miles on it. I have a week of vacation left so I am trying to figure out if I need to order some injectors and a turbo.
Matt
E99 F350 ECSB SRW 4x4 ZF6 3.73 Adrenaline HPOP, chip, tymar
Mtack is offline
post #2 of 16 (permalink) Old 09-23-2010, 03:12 AM
I get's it did!
SledYanker's Avatar
Re: Signs of injectors going bad?
buzz 'em, that'll tell ya.
When you get that AE, that is... seems a little early for the injectors if the truck was/has been maintained well.
SledYanker is offline
post #3 of 16 (permalink) Old 09-23-2010, 10:56 PM Thread Starter
Mtack's Avatar
In the 8 years I have owned it I have always changed the oil every 3000 miles, fuel filter about every 10,000 and the air filter every time it looks dirty. When I wrenched for a living I changed a few injectors with less miles but it was always obvious. I just have no idea what they do before they go clear out or if they just go out without any warning. I will definitely know more after I get the AE.
Matt
Mtack is offline
post #4 of 16 (permalink) Old 09-23-2010, 11:25 PM
O_O
Aspiring 7.3 Dude
O_O's Avatar
My 99 F 350 does that exact same thing! I can't figure it out either! Please let me know if you figure something out!
O_O is offline
post #5 of 16 (permalink) Old 09-27-2010, 08:59 PM
aklim's Avatar
Could the injector be dirty? Only way to tell that is to have it bench tested.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #6 of 16 (permalink) Old 09-27-2010, 09:12 PM
I have the EXACT same problem!!
It almost feels like strong wind is bucking the truck at cruise from the front. Just a real slight hesitation in the Low RPM range...
I have AE But I have yet to hook the truck to it to see what the deal is.
2001 F-250 4x4 Crew shortbox, Optix gauges, DP F5 60towHighAlt, 80E, 100, 120. WW, ITP Boost Annihilator. DIY 6637 intake.
redmist is offline
post #7 of 16 (permalink) Old 09-28-2010, 11:24 PM
Beef
run your tests, if your spending 350+ bucks for the program might as well use it.
You can use the live data screen and see several variables in live time. Also use the CCT and buzz test. It would be a good excuse to get injectors, oh and buy one size up at least.
W/ that many miles, get Swamped, trust me on this one injectors and a new BB woke mine up before my injector issues resurfaced. Dave and Jon answer ALL their emails quickly and always return my calls. And i've spent only a small portion of $$ w/ them. Heck they fielded all my info on other problems.
good luck
"New" 05 no payment, all factory 289k
powerlifter405 is offline
post #8 of 16 (permalink) Old 09-29-2010, 12:25 PM
Fixing Broken Stuff
toolmangary's Avatar
First thing I would do.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #9 of 16 (permalink) Old 09-30-2010, 03:27 AM Thread Starter
Mtack's Avatar
After seeing the huge price drop on 250/100% injectors from Ryan Casserly I almost hope I find an injector issue! I will run some tests as soon as I receive my Autoenginuity.
Matt
Mtack is offline
post #10 of 16 (permalink) Old 10-03-2010, 02:57 PM Thread Starter
Mtack's Avatar
I guess it is not an injector issue. I did the buzz test and not one sounded any different. I also ran the cylinder contribution test and got nothing. It is so slight and you have to lug it down to even notice. I guess I `ll have to wait and see if it gets any worse.
Matt
Mtack is offline
Human Verification
