PO603 Code - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-02-2008, 06:53 AM Thread Starter
ADubDiesel's Avatar
PO603 Code
Hey guys new to the site but have been on lots of other forums. Anyways, I'm away at college and my dad was driving the 01 yesterday and said it started running rough and the CEL came on. He pulled P0603 from the edge evo. Just wondering what this is. IDM and CPS have less than 4,000 miles on them. I know it sets a code everytime you reprogram the evo but I don't believe this is it.
PO603-PCM processor
keep alive memory
Kam Error
1995 Ford F-250 7.3 (Sold)
1998 Nissan Maxima 3.0
ADubDiesel is offline
post #2 of 10 (permalink) Old 03-02-2008, 03:51 PM
Re: PO603 Code
You should only get that code when you unhook the batteries.
SmokeWagon is offline
post #3 of 10 (permalink) Old 03-02-2008, 06:20 PM Thread Starter
ADubDiesel's Avatar
Re: PO603 Code
I don't think he unhooked the batteries but I'll give him a call to make sure.
post #4 of 10 (permalink) Old 03-02-2008, 06:32 PM Thread Starter
ADubDiesel's Avatar
Re: PO603 Code
Bad fuel is a possiblity. We run biodiesel in the 01 and our TDI's but have never had any problems with it. (I'll at bio to my sig) I think he just filled up too because I drove it last week to a rental house when he was in Mexico and it was almost empty. Possibly a fuel filter?
post #5 of 10 (permalink) Old 03-02-2008, 06:41 PM
FNG
Dave's Avatar
Re: PO603 Code
Originally Posted by jvencius View Post
I thought P0603 would show anytime you had programmed/chipped the PCM and by itself, wasn't anything to worry about.
There might not be any connection between the CEL/rough running and P0603, since IIRC P0603 won't set a CEL. Could he maybe have gotten some skunky fuel?
P0603 shows up every time you change a tune
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #6 of 10 (permalink) Old 03-02-2008, 08:12 PM
Re: PO603 Code
Wrong on some the fords they have built into the pcm/the truck tex code. You will get this dtc without unhooking anything. This code is normal and you dont need to worry about it.This dtc only set when you run a new program and or unhook your batterys. I have already been through this dtc with edge and Bill at powerhungry.
2002 F350 DRW, 38r Turbo, Terminator T500, REG return fuel system, CTS Evo Custom tuned by Bill at Powerhungry Performance, bts converter, S&B intake, Snows Stage 3 Water/Meth. Mcculloch hids 6k.
toypuller is offline
post #7 of 10 (permalink) Old 03-02-2008, 09:08 PM Thread Starter
ADubDiesel's Avatar
Re: PO603 Code
Ok I thought there was a code everytime the pcm was accessed. Just got off the phone with my dad. Said its running fine in stock form, he's gonna put it back on to the tow program and just see what happens.
post #8 of 10 (permalink) Old 03-03-2008, 03:26 AM
urbanwheeler's Avatar
Re: PO603 Code
evo's don't plug into the pcm
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #9 of 10 (permalink) Old 03-03-2008, 05:20 AM
Re: PO603 Code
You are right but they do access the pcm to perform program changes causing a p0603.
post #10 of 10 (permalink) Old 05-25-2014, 04:34 AM
Re: PO603 Code
I disconnected battery to clean cables, then found truck would not start and have code po603.
How do I correct to get truck to start and run as before?
lgaston@gmail.com is offline
Human Verification
