7.3 PSD black smoke no power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 09-15-2010, 12:56 AM Thread Starter
My friend just got his truck back together he did studs and gaskets. Hes got 100hp injectors exhaust and intake. The truck takes a while to build oil pressure then it finally fires off and has a loud knock on the drivers side. when you hit the gas it smokes like mad, more then it ever did. Could it be the ICP? the truck sat for a few months.
Gasoline Sucks is offline
post #2 of 29 (permalink) Old 09-15-2010, 01:36 AM
Keyboard Thug
Big Bore's Avatar
Re: 7.3 PSD black smoke no power
Did he do the injectors at the same time? If so it takes a while to bled the air out of the HPO system, like a few WOT passes on the hiway.Sitting for a few months shouldnt be a problem unless he has a leak somewhere, o-rings etc.
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #3 of 29 (permalink) Old 09-15-2010, 01:44 AM
stackedstroker's Avatar
he didnt take anybodys newby advice and put a plastic bag over the intake for more smoke did he?
1999.5 F 350 crew cab dually 4x4, 330,000mi, TS 6 position, Edge monitor, Itp regulated return, sinister boost inhilator, ccv mod, afe stage ll, s475, 300cc 200% hybrids, Adrenaline HPOP, Airdog 150, Jasper class 1 full built tranny, triple disc Torque converter, AIH delete, 4" exhaust.
stackedstroker is offline
post #4 of 29 (permalink) Old 09-15-2010, 02:07 AM Thread Starter
The injectors were in the truck and ran good before doin the hg and studs. Now it's hard to start and doesn't make power as if it has no boost. If your on the gas it smokes like there is an intercooler hose disconnected. We drove it around for a few mins wide open a bit and all it did was smoke. It also takes aminute to build oil pressure then it fires. Any help is appreciated!
post #5 of 29 (permalink) Old 09-15-2010, 02:14 AM
99redf350's Avatar
there is a air pocket in the hpo... i had to let mine idol for 3 hrs then took it for a long drive...
late 99 f350, guages, mbrp, cold air, SWAMPS 300/200 hybrids, gen 3, fuel lab, fuel regulator, gt42r and of course a ts tuner by swamps , currently broke
99redf350 is offline
post #6 of 29 (permalink) Old 09-15-2010, 02:29 AM Thread Starter
Ok, btw there are no codes either. It ran like dog #### when we did injectors but it cleaned up after a quick ride. We will let it run a while thanks!
post #7 of 29 (permalink) Old 09-15-2010, 04:32 AM Thread Starter
Let it run about 1 and a half hrs and drove it about 5 miles still no power programed back to stock no improvement and back to original setting still no improvement
post #8 of 29 (permalink) Old 09-15-2010, 04:41 AM
Metal - It kicks your ass
What are all the mods done to the truck...?
And how big are 100hp injectors?
Last but not least, whos tunes?
Modded L99
dirtboy25 is offline
post #9 of 29 (permalink) Old 09-15-2010, 05:10 AM Thread Starter
4 inch turbo back exhaust, afe cold air intake, super chips programer and diesel care nozzles what they call 100 hp
post #10 of 29 (permalink) Old 09-15-2010, 05:12 AM
So stock injectors with 100% nozzles.
If im right 100% nozzles are going to flow twice as fast, very little atomization with 140cc of fuel. Along with a stock turbo and canned tunes. I would assume it's bound to be a bit smokey.
Modded L99
Human Verification
