7.3 white smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 85 (permalink) Old 06-12-2010, 09:40 PM Thread Starter
KSC350's Avatar
7.3 white smoke
i have a 2003 f350 with a 7.3 and it just started blowing white smoke under acceleration..I checked the compressor wheel and the turbo is fine no oil in the fuel bowl and its not missing or blowing white smoke all the time..All gauges and temps are good.. Any ideas??
KSC350 is offline
post #2 of 85 (permalink) Old 06-12-2010, 10:10 PM
All done now
Arisley's Avatar
Re: 7.3 white smoke
Take a whiff of your exhaust, let us know what it smells like.
Arisley is offline
post #3 of 85 (permalink) Old 06-15-2010, 04:15 AM Thread Starter
KSC350's Avatar
Re: 7.3 white smoke
Took a quick smell...didnt really notice anything different?
96 CCLB DRW ZF5 in the works.....
03 F250 CCSB 6.0, 4" mbrp turbo back with cat delete. Glowshift 4 pillar guages. Erics tunes. on 35's.
03 F350 7.3 RCLB DRW ZF6. Stage 2 afe intake, stage 1 160 beans injectors, forged rods, dp tuner, 4" straight pipe, wicked wheel turbo upgrade with 1.0 non-wastegated, i, isspro gauges, southbend clutch.
KSC350 is offline
post #4 of 85 (permalink) Old 06-18-2010, 01:03 AM Thread Starter
KSC350's Avatar
Re: 7.3 white smoke
Any ideas guys?
KSC350 is offline
post #5 of 85 (permalink) Old 06-18-2010, 01:11 AM
Re: 7.3 white smoke
does it run rough? any other symptoms?
96 Stroker, Tymar , 4" Straight pipe, Banks 1.0 housing, Mod. comp wheel, IDM Mod., Edge Evo, 35's
powerstrokedan96 is offline
post #6 of 85 (permalink) Old 06-18-2010, 01:11 AM
Busy Busy
Marty's Avatar
Re: 7.3 white smoke
Fuel pressure?
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #7 of 85 (permalink) Old 06-18-2010, 01:49 AM
HAMMER DOWN
Re: 7.3 white smoke
check fuel pressure guarentee its either clogged injectors fuel line or filter had my 2001 do the samething got a bad batch of fuel had to pull the fuel bowl clean that the lines going to each head and the screen in the ports...
All Stroked OUT is offline
post #8 of 85 (permalink) Old 06-19-2010, 01:59 AM Thread Starter
KSC350's Avatar
Re: 7.3 white smoke
Okay thanks for the imput guys..Symptons: Runs fine, doesent sound any different and no loss in power. Under hard accell it blows white mixed with black and when its in neutral if i rev it a puff of white comes out with some black. Fuel bowl was clean and so was the filter. I did notice this was only on the higher tuner setting..When i was on stock setting since it doesent blow any black smoke, doesent blow any white either
KSC350 is offline
post #9 of 85 (permalink) Old 06-19-2010, 02:44 AM
fueled by Colecovision
golfer's Avatar
Garage
Re: 7.3 white smoke
with the truck running, at full operating temperature...
unscrew the oil fill cap from the passenger side valve cover...if it has a steady haze (oily mist) then you're in not bad shape...
however...if there is a puff, puff, puff. (as if there is moderate pressure behind it)...then I'm afraid that you've probably lost a cylinder (rings, cylinder walls or cracked piston)...
any oil consumption (or "making" oil?)
when compression is gone in a cylinder...the fuel that the injector is injecting into that cylinder can increase the oil level in the crankcase.
take care~
Dave
golfer is offline
post #10 of 85 (permalink) Old 08-07-2010, 02:49 AM
Re: 7.3 white smoke
My truck does the exact same thing. It blows some white smoke sometimes just like yours. I cant figure it out but I may replace injectors.
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS STAGE 1 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
99STROKINSMOKIN is offline
Human Verification
