7.3 engine removal procedure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 05-12-2010, 03:20 AM Thread Starter
I dont see a thread or sticky on this anywhere. Does anyone have a write up on it?
PMRCM#1
slowleak is offline
post #2 of 17 (permalink) Old 05-12-2010, 03:44 AM
CtG
Re: 7.3 engine removal procedure
Not that I know of... I'd imagine the hardest parts would be exhaust separation and TC bolts? Just properly marking and detaching the electrical goodies and plumbing. And having a cherry picker that can lift 1000lbs safely and high enough.
Family Rides-
99.5 F250 PSD SC 4x4 SD: BTS, SS 4" Exh, 6637, 6-pos chip, 4" lift, Reg. Return, FFD 160CC Single's, GTP38R, Adrenaline, Fuel Bowl Delete- 410HP/828TQ Wheel
02 Excursion 4x4 PSD: 4" DP-back w/ Aero-Turbine, Larry's Black Box, BTS
CtG is offline
post #3 of 17 (permalink) Old 05-12-2010, 03:48 AM Thread Starter
Thats one hell of a lift. I was debating pulling the tranny/tcase out with the motor but no way in hell is that going to happen
PMRCM#1
slowleak is offline
post #4 of 17 (permalink) Old 05-12-2010, 04:04 AM
Haters Gonna Hate
Fordfreak4life's Avatar
id remove the grille radiator support, trans, ic, radiator, well pretty much anything in front of the motor and lift it up a couple inchs and slide it out the front
Fordfreak4life is offline
post #5 of 17 (permalink) Old 05-12-2010, 04:08 AM Thread Starter
Im pretty much done at this point, I had just realized there were no write-ups and such anywhere. Figured someone might have a link or something.
PMRCM#1
slowleak is offline
post #6 of 17 (permalink) Old 05-12-2010, 05:20 AM
bpcheramie's Avatar
Send me the truck and you wont have to worry about it.... You can keep the tranny just need the other parts.
02 F250 All Stock (Project Cheapo)
01 Excursion 4X4 -SOLD
7.3 with Forged Rods (30K) RIP 2/17/2010
7.3 with PMRs (139K) RIP 2/17/2009
01 Excursion 4X4 - RIP 2/22/2008
bpcheramie is offline
post #7 of 17 (permalink) Old 05-12-2010, 08:01 PM
dinnerbooter treasurer
genuineford's Avatar
Remove batteries.
Remove turbo, intercooler pipeing
Unplug main engine wiring harness, When I do it I take the harness completely off the the engine.
Remove the power that feeds the glow plug relay and bring that out with the engine.
Remove cooling fan and shroud.
Drain coolant and remove radiator.
Remove intercooler.
Remove ground wires for starter and one on back of engine by down pipe
remove upper radiator bracket.
Unbolt AC compressor and lay off to the side, do not disconnect hoses
I take off the accessory brackets, the one with the power steering i just lay off to the side.
Remove starter
Remove torque converter shield then torque converter bolts
Remove bell housing bolts
Remove engine mount bolts
Start lifting engine, with jack placed under transmission.
I don't think I missed anything but feel free to add something if it is not there.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #8 of 17 (permalink) Old 05-12-2010, 08:08 PM
Busy Busy
Marty's Avatar
No need to remove the batteries or starter
See it right there ->
Just disconnect the batteries.
that is all.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #9 of 17 (permalink) Old 05-12-2010, 08:11 PM
Yeah I also dont take the whole front clip off of my truck. It is easy enough to get off so I don't mind.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
post #10 of 17 (permalink) Old 05-12-2010, 08:12 PM
Busy Busy
Marty's Avatar
Oh yeah, flip the A/C condenser off to the side too instead of removing the lines...
Elkton, Maryland
Marty is offline
Human Verification
